EGT or Oil Temp Gauge?
Old Jun 1, 2009 | 06:49 PM
ATX350's Avatar
ATX350
Default EGT or Oil Temp Gauge?
Trying to gather the remaining parts for the powelab kit. Wanted to get your opinion on the guage which is more accurate to indicate an issue. I will have three gauges 2 of which will be boost and WB A/F ratio.
The last gauge I am undecided on. Do you already F/I guys prefer Oil Temp or EGT. If you had to choose which would you go with?
Thank you.
Old Jun 1, 2009 | 07:25 PM
frankie945's Avatar
frankie945
I would prefer a oil temp, if I had a choice between the two.
Old Jun 1, 2009 | 07:35 PM
SQLSolarZ's Avatar
SQLSolarZ
Oil Temp
Old Jun 1, 2009 | 10:04 PM
scotts300's Avatar
scotts300
Oil temp over EGT, although I also highly rec'd water temp and fuel pressure. The Defi link system simplifies things.
Old Jun 1, 2009 | 10:22 PM
ATX350's Avatar
ATX350
How accurate are glowshift gauges? It seems Defi are the most popular here but are they anymore accurate than other brands?
Old Jun 2, 2009 | 07:15 AM
djamps's Avatar
djamps
You already have A/F so you don't really NEED EGT if you know how to read the A/F properly and keep a close eye on it. Get the oil temp...cooked oil = fast track to fail.
Personally I went with EGT instead of A/F since I don't want to be constantly watching the damn thing all the time.
Old Jun 2, 2009 | 09:51 AM
Cass007's Avatar
Cass007
I would say neither and get an accurate water temp gauge instead. If EGT and Oil are your only options, then go with oil.
You could get one of the combo gauges that read several sensors, but most people don't use them all after a while and just keep one face the bulk of the time.
Old Jun 2, 2009 | 10:02 AM
Clint@Altered's Avatar
Clint@Altered
Preferably both when you can swing it. Do the EGT now, it will be easier to install during the turbo installation versus later. Do the oil temp later down the road.
Old Jun 2, 2009 | 10:04 AM
ATX350's Avatar
ATX350
Very informative. Thank you all.
Old Jun 2, 2009 | 10:11 AM
Driven1's Avatar
Driven1
Professional
I keep having my A/F's go bad (sensors) so I'd say EGT. Can be very helpful at higher speeds too when running it hard.
As far as accuracy...They'll all be off somewhat (I'd say I've noticed 5%-10% depending on what is being read)...but all you need to know as the driver is where they should be in reference to that car. If you want better accuracy imo you'd use virtual dash set-ups off the EMS you're running and that gives you everything it's just not as easy to read on the fly.
apex locator
Jul 23, 2021 02:27 AM
SharX59
Sep 27, 2015 09:23 AM
