Aps TT kit with Forged Performance WGA issue?
Old Jun 4, 2009 | 07:34 AM
FoxZee's Avatar
FoxZee
Default Aps TT kit with Forged Performance WGA issue?
I have the APS TT kit on my 350z and installed the Forged Performance WGAs on the car but cant get them to hold more than 6.5psi of boost? I have the 5-10psi springs in them and would like to be running at least 8.5-9psi of boost. We tried running both the boost controller from aps as well as a turboxs boost controller and cant get the WGAS to hold any more boost. Any ideas of what could be causing this? Maybe the length of the WGA arms?
Thanks Everyone
Old Jun 4, 2009 | 07:42 AM
rcdash's Avatar
rcdash
You mean Forced Performance? Is this the standard APS kit with internal wastegates? If you have a boost controller with internal wastegates, it should be able to hold up whatever boost you set it at unless exhaust backpressure overwhelms the wastegate.
Old Jun 4, 2009 | 07:45 AM
doug's Avatar
doug
I've seen a couple threads on this before.. and it was a matter of using the other springs.. and Raj is right.. you're confusing the names of the companies... Forged Performance doesn't make that wastegate
edit: i thnk the place is called Forge Motorsports
Old Jun 4, 2009 | 07:47 AM
FoxZee's Avatar
FoxZee
Its these wastegates
http://forgedperformance.com/store/p...cat=472&page=1
So i might need to just order stronger springs for them?
Old Jun 4, 2009 | 07:49 AM
doug's Avatar
doug
https://my350z.com/forum/3982227-post166.html
Old Jun 4, 2009 | 07:50 AM
doug's Avatar
doug
oh here is a good one: https://my350z.com/forum/forced-indu...ing-rates.html
Old Jun 4, 2009 | 08:25 AM
boostintt's Avatar
boostintt
i had the same issue with my HKS tt kit dual gt2871r garrett turbos. i was only able to boost 8 psi which gave me 395 on the dyno dynamics. i m not sure if i only have to change the springs or the whole actuators???
350z82
Oct 1, 2015 06:25 PM
