Question about tuning
Old Jun 11, 2009 | 07:22 AM
djamps's Avatar
djamps
Default Question about tuning/knock
When I swapped my utec one of the map sensor wires was loose after plugging it into the new one (stupid turboxs molex plugs, pure suck)...so basically the UTEC wasn't taking over fuel deliver in under boost for the first couple pulls until we figured out the prob. It felt like hesitation as the utec was pulling timing a few times on the pulls.
We quickly found the problem and got the map working correctly after a couple of pulls but the utec registered several knock events prior and had been pulling timing. I heard the knock a bit too, like a brief ticking sound as the utec pulled timing over and over.
Everything is fine now...but do you think those few knocking events due to the map not working could have damaged anything?
Old Jun 11, 2009 | 08:08 AM
SmallTuner's Avatar
SmallTuner
if ur car is still runing fine, i think your ok.
if u have a built motor im sure your ok, but if u have a stock motor, then only time can tell.
Old Jun 11, 2009 | 08:24 AM
djamps's Avatar
djamps
Thanks man thats what I thought (only time will tell) LOL. TurboXS molex plugs FTL! Even the tuner box had the same issue with a wire coming out of the molex.
Old Jun 11, 2009 | 08:27 AM
SmallTuner's Avatar
SmallTuner
how much boos u where runing when u did the dyno pulls ?
Old Jun 11, 2009 | 10:09 AM
djamps's Avatar
djamps
~6-7psi. The (reflashed) stock ECU did suprisingly well until the maf was maxed out around 5k which was the cause of the lean condition. And the UTEC was quickly pulling timing each time -- It felt like small hesitations like VDC was kicking in at which point I immediately let off the gas.
Old Jun 11, 2009 | 10:25 AM
SmallTuner's Avatar
SmallTuner
good in that case dont worry u gonna be jus fine.
the problem is when u continue up top to 6800RPM
ull be fine trust me
just have fun
Old Jun 11, 2009 | 04:27 PM
rcdash's Avatar
rcdash
UTEC FTL Go Haltech and never look back!
Old Jun 12, 2009 | 01:48 AM
SmallTuner's Avatar
SmallTuner
Old Jun 12, 2009 | 02:05 AM
wannabuy350z's Avatar
wannabuy350z
i have to agree on haltech, such a good ems. worth every penny!
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
KOF
Tuning
Sep 30, 2015 04:09 AM
