Question about 06 hi-rev motor?
Old Jul 3, 2009 | 10:51 AM
Nismokingz33's Avatar
Nismokingz33
Unhappy Question about 06 hi-rev motor?
Hi I had a blown engine in my 03 Z and replaced it with a vq out of an 06 later to find out it was a hi-rev motor. Do they make superchargers for it?
Old Jul 3, 2009 | 10:54 AM
cdoxp800's Avatar
cdoxp800
Yes.. Also it's the 06 (manual) motor is called a RevUp
The Hr motor are from the 07 an 08's and currently no SC for them.
Old Jul 3, 2009 | 11:14 AM
Nismokingz33
Thanks for the correction. Do you know if stillen makes a sc for my 06 revUp?
Old Jul 3, 2009 | 11:23 AM
seZy350's Avatar
seZy350
yes... heres a link to some other superchargers available for the vq http://www.350zmotoring.com/forums/f...r-systems.html
google is your friend.
Old Jul 3, 2009 | 12:35 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
Since you are in Cali and looking at superchargers you should go with the Vortech, its CARB certified.
Old Jul 3, 2009 | 01:48 PM
Nismokingz33
Ok thanks guys I'll do seme research on them both
Old Jul 3, 2009 | 02:40 PM
XKR's Avatar
XKR
This is true.....Go with the Vortech......
With the stillen...you have to go with that hood.....not the best looking IMO.
Old Jul 3, 2009 | 02:53 PM
quiksilver38's Avatar
quiksilver38
how did your engine blow ?
Old Jul 3, 2009 | 08:55 PM
Nismokingz33
I was pushing a 50 shot of nitrous and I snaped a piston rod. And my engine had 120 thousand miles on it.
Old Jul 4, 2009 | 10:18 AM
superchargedg's Avatar
superchargedg
Damn Noobs
Please dont go with the stillen as it just an expensive non power maker.
Old Jul 4, 2009 | 02:07 PM
s.mckenzie82's Avatar
s.mckenzie82
WOW, blown motor on a 50 shot! you must have been doing something wrong. I was running a 100 shot on a stock block for a year and a half with out a tune. The motor also had 65-70K miles!
Old Jul 5, 2009 | 09:21 AM
Nismokingz33
What happened was I was driving lost oil pressure Didnt realize it so I don't know how long I was driving like that for? Driving down the 405 doing about 80 it was late at night so I squezed brought it up to 135 and heard a loud claping sound. Not really sure what went on that caused me to loose my oil pressure?
Old Jul 5, 2009 | 09:32 AM
s.mckenzie82
Damn bro that sux, rev-up motor?
Old Jul 5, 2009 | 09:33 AM
Nismokingz33
Stillen is that bad? I guess I like the stillen because it seems like a clean simple set up no messy tubes running everywhere like turbos.
Old Jul 5, 2009 | 09:35 AM
Nismokingz33
No the blown one was the non rev-up. My new set up is rev-up no more nitrous though lol
Old Jul 5, 2009 | 09:50 AM
s.mckenzie82
I dunno, I like NOS. It's so easy to deal with. I've had turbo cars, SC and NOS.... Hands down NOS was the easiest to maintain and cheaper.
Old Jul 5, 2009 | 09:54 AM
Nismokingz33
Well I have simple bolt ons headers test pipes nismo exhaust kinetix plenum injen short ram intake. Any mods you recomend for me to run nitrous safely?
Old Jul 5, 2009 | 10:03 AM
superchargedg
Damn Noobs
Its not that its a bad setup its just that for all the money you spend you do not make anywere near the power of a turbo or a vortech.I ran it for 3 years and installed it when the car was 6 months old cause there wasnt anything else not blowing engines up.
Old Jul 5, 2009 | 10:38 AM
Nismokingz33
I'm gonna look into the vortech sc a little closer thanks
Old Jul 5, 2009 | 10:54 AM
s.mckenzie82
Honestly bro for me NOS was just common sense. I called Holly (the place where I got my pills from) and asked them what pills I should run to make a 100 shot on my particular set up. The tech will give you two pill sizes (1 will be for Fuel and the other for NOS ** Wet setup only, which should be the only way you should run NOS***) What ever pill size they told me I would go 1 size bigger just to ensure I didn't create any lean conditions.
The real reason why people break motors on NOS is because there is a massive just in torque. Don’t spray before 3K RPM's and you should be able to run a 100 shot on your car for years. To solve that problem you should have a RPM activated window switch, a bottle warmer would help to make sure your PSI is where it should be... Other then that (hypothetically speaking) you shouldn't have any problems. Plus you can wait for chicks to walk by your car with skirts on and purge the NOS and lift them dresses like the wind....
Just playing, but if you have any questions about NOS I honestly feel I have a shat load of knowledge just sitting around in this enormous dome of mine!
