Greddy twin turbo over heat. HELP!!!
Old Jul 5, 2009 | 08:55 PM
specialist's Avatar
specialist
Angry Greddy twin turbo over heat. HELP!!!
-2003 g35 coupe
-greddy twin trubo
-oil pan spacer
-ams radiator
-samco hoses
When i turn on my a/c i start to over heat what do i need to do to fix this.
I am 50/50 anti freeze and dist water.
Please help!
Will a nismo thro stat work and fix my problems???? please help
Old Jul 5, 2009 | 09:59 PM
Chomorro's Avatar
Chomorro
Mine did the same thing, un plug the ecu and start the car to see if both fans turn on. One of mine wasnt working. Replaced it and no more over heat.
Old Jul 5, 2009 | 11:48 PM
nyqueenz's Avatar
nyqueenz
hows is your water pump?
Old Jul 6, 2009 | 05:08 AM
Zivman's Avatar
Zivman
Originally Posted by specialist
-2003 g35 coupe
-greddy twin trubo
-oil pan spacer
-ams radiator
-samco hoses
Please help!
nismo stat won't do a thing for peak temps. Just opens sooner.
you don't have any issue with heat without the A/C on?
Does the needle just rise? or do you have coolant spewing out?
The best thing I can suggest for overheating is a larger radiator and higher percentage water mixture. Beyond that, look at opening up the front bumper, keeping all coolers up front clean. possibly get an oil cooler
Old Jul 6, 2009 | 05:42 AM
RandomHer0's Avatar
RandomHer0
Are you actually getting cold air? Maybe you have air in the system? I have Greddy TT with stock cooling components on my G35 and don't have any issues. I run my AC just for the idle bump lol
Old Jul 6, 2009 | 06:21 AM
specialist's Avatar
specialist
New water pump.
you don't have any issue with heat without the A/C on? No problems 50% the needle reads. I can boost all day no problems.
When i turn on ac it starts to climb
I have a big ams rad
Old Jul 6, 2009 | 06:45 AM
RandomHer0's Avatar
RandomHer0
I have no issue with the AC or or OFF. I have no heating issues...
Do a coolant flush? Add some water wetter?
Old Jul 6, 2009 | 06:48 AM
specialist's Avatar
specialist
how much water wetter how many bottles?
Old Jul 6, 2009 | 06:52 AM
rcdash's Avatar
rcdash
New water pump.
Make sure you're fans are kicking on when the A/C is on. Otherwise thermostat issue or air in the cooling system.
Old Jul 6, 2009 | 07:21 AM
specialist's Avatar
specialist
has any thought to use water wetter and just water?
Old Jul 6, 2009 | 07:31 AM
Zivman's Avatar
Zivman
you could try this... but considering the problem seems to be only when the A/C is on, I would think it is something besides the coolant. You need to check the fans, check the thermostat (though I don't think that is the issue), check to make sure coolers are clean and getting air
Old Jul 6, 2009 | 07:35 AM
specialist's Avatar
specialist
i have the stock bumper for a g35 with rebar that is modded
Old Jul 6, 2009 | 08:44 AM
psychoballistic's Avatar
psychoballistic
+1 I do the same thing on my car for the idle bump.
I'm on stock cooling components also, no issues.
Old Jul 6, 2009 | 09:24 AM
doug's Avatar
doug
+2..
Old Jul 6, 2009 | 10:13 AM
specialist's Avatar
specialist
i will let you know tonight i am going to bleed system again tonight
thanks
Old Jul 6, 2009 | 02:36 PM
boostintt's Avatar
boostintt
did you "burp" the coolant system?
Old Jul 6, 2009 | 02:57 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Bingo as i bet the fans arent coming on when you turn the ac on.You either have a bad relay or rad coolant temp sensor.
Old Jul 6, 2009 | 04:50 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
My guess is air in the cooling system. If the ac fan wasn't coming on your ac would work poorly but would usually not cause an immedaite overheat issue.
Old Jul 7, 2009 | 06:38 AM
Reality350's Avatar
Reality350
New water pump.
Did your problems start after installing the ams rad?...
Must be air in the cooling system..
Who did your install?
Old Jul 7, 2009 | 08:07 PM
deanfootlong's Avatar
deanfootlong
run the car with the coolant bleeder valve open till it starts to spew coolant out. you'll see air bubbles come out of there then straight coolant. then tighten valve. see if that fixes it.
