Kinetix Velocity Manifold + Vortech Numbers
Old Jul 7, 2009 | 08:20 PM
tylerxfire's Avatar
tylerxfire
Originally Posted by bd0g36
It's a G homie
Here she is with those aforementioned 20's
ah ic..more acceptable but damn then again ur just adding more weight to something already heavy instead of lightening up..
Old Jul 7, 2009 | 10:58 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
In all honesty, I would buy the new Kinetix SSV just to reduce weight and heat in the engine bay as long as it doesn't hurt the performance. But, that's just me.
Old Jul 8, 2009 | 03:03 AM
Zivman's Avatar
Zivman
you would at least sand out the "KINETIX" on it, no?
Old Jul 8, 2009 | 06:28 AM
Motormouth's Avatar
Motormouth
does that SSV thing lose weight? I'd be surprised... the stock plenum is aluminum I think.
Old Jul 8, 2009 | 08:00 AM
bd0g36's Avatar
bd0g36
It's 10lbs lighter than the stock plenum, probably because it is overall quite a bit smaller than the stock plenum.
After driving around some more today, the Kinetix is definitely making a difference. I am noticing a lot more power when I am in high gear at low rpms. Where I used to down shift to pass someone, today I just kept it in 4th and it pulled really nicely (note, a significant difference). And I am loving the sound, no radio for me, just windows down, and that alluring engine soundtrack.
Old Jul 8, 2009 | 08:13 AM
Z_Nick_Z's Avatar
Z_Nick_Z
as long as your happy man
Old Jul 8, 2009 | 09:22 AM
rcdash's Avatar
rcdash
Thanks to the OP for sharing a dyno! Kudos.
This design is definitely better than their original (which isn't saying much). We need real back-to-back dynos, a sub-$400 price tag for something that is welded together and not cast, and a different manufacturer to eliminate the notoriety (shame!) of bearing a Kinetix product. Someone should copy this and make a lower cost piece for those that want to see a flatter torque curve above 6000 rpms. It'd sell well I think for $400, especially if it doesn't have "Kinetix" etched onto it.
Old Jul 8, 2009 | 09:35 AM
bd0g36's Avatar
bd0g36
I totally agree with everything you said. I figured I would take one for the team on this and be the guinea pig. For the $$, I don't think I would recommend it for everyone. If it was around the $400 price range and from a company that didn't make everyone gag when their name was mentioned, it would be a true winner.
Old Jul 8, 2009 | 03:57 PM
ironx's Avatar
ironx
would love to see a vid of the beast in action got any with the new setup
Old Jul 8, 2009 | 05:50 PM
oro's Avatar
oro
Definitely one of the biggest reasons I miss my old Kinetix plenum, when you hit high RPM it sounds like a metallic growling. Music to the ears, I assume it's because the stainless steel let it reverberate a bit and because it is a more "open" design then the stock or Cosworth.
Old Jul 8, 2009 | 09:48 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
I feel the same way. Actually there was one Japanese brand that came out with very similar plenum, but I think they stopped making it. I tried very hard to find it, but no luck...
Old Jul 8, 2009 | 11:02 PM
marra23's Avatar
marra23
curious to what this would do on a higher rpm turbo setup.
Old Jul 10, 2009 | 11:18 AM
g35keys's Avatar
g35keys
ahh brian you went ahead and put it on...you trying to catch up again...you stay down in power you and your damn camera I'm oh so jelous of!! Man I'll be up there in the next two weeks for the test pipes ...You should come keep me company sittin there for 2+ hrs by myself
Old Jul 10, 2009 | 11:37 AM
bd0g36's Avatar
bd0g36
Just let me know when you're coming down, and I'll be there
Old Jul 15, 2009 | 10:32 AM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
This is what I WANT!!!! ----> https://my350z.com/forum/members/pap...-manifold.html
Any more info on this plenum???
Old Jul 15, 2009 | 10:47 AM
marra23's Avatar
marra23
think they're from Thailand....discontinued i guess
http://www.kuengineering.net/default.aspx
