air to fuel ratio problem
Old Jul 8, 2009 | 11:38 AM
bldg250z's Avatar
bldg250z
Default air to fuel ratio problem
im not sure why this is happening please help!!1
i have a txs tuner wideband connected on my 03 350z with a turbonetics kit on it for tehe past few days my reading while idling has been around 14.8 to 15.4 and then drastically drops to 10.8 without me moving a thing and then steadily goes back up before dropping again.
so if you have any idea whats causing this i will chwck my o2 sensor today and replacing it with a spare and will also check my connections but please give me input on wat youguys think it might be
Old Jul 8, 2009 | 11:46 AM
bldg250z's Avatar
bldg250z
Default short clip
hopefully this works
Old Jul 8, 2009 | 12:12 PM
rcdash's Avatar
rcdash
misfire. no spark = raw fuel out the exhaust
Old Jul 8, 2009 | 09:57 PM
streetzlegend's Avatar
streetzlegend
When the a/f drops into 10's do you feel the car idle differently? change in tone, shakes a lil bit, etc...?
Old Jul 9, 2009 | 11:32 AM
ADMAN's Avatar
ADMAN
Is this all of the time, regardless of engine temp? Or, only right after startup?
Old Jul 10, 2009 | 06:38 AM
bldg250z's Avatar
bldg250z
the idle drops maybe like 100 rpms to 150 like barely with no vibration just that small change in idle when it drops to the 10's
plus
all this happens right after warm up of the car as soon as its up to the 14's 15's its starts dropping .....?????
Old Jul 10, 2009 | 06:42 AM
djamps's Avatar
djamps
Sounds like a misfire. Are you running colder plugs? Have you checked your gaps?
Old Jul 10, 2009 | 08:23 AM
bldg250z's Avatar
bldg250z
i have 1 step colder ngk's i checked the spacing when i put them in and set them at .34 i think..... but it wouldnt hurt checking them again
Old Jul 10, 2009 | 08:43 AM
rcdash's Avatar
rcdash
UTEC?
Old Jul 10, 2009 | 10:49 AM
SmallTuner's Avatar
SmallTuner
post ur map, this will help.
if u have a utec, make sure that u reflash it befor using it. even if its working fine with u.
Old Jul 10, 2009 | 11:35 AM
bldg250z's Avatar
bldg250z
ill get the map later today....and yes i am using utec....
Old Jul 10, 2009 | 01:35 PM
streetzlegend
I dont think its misfiring, otherwise you will definitely feel it shaking and it would be lean most likely.
Uriyo_
Sep 8, 2021 08:46 AM
