HELP - No Throttle response - TN single turbo kit
Old Aug 14, 2009 | 02:10 AM
zerosec's Avatar
zerosec
Arrow HELP - No Throttle response - TN single turbo kit
ok so here's my problem,
i own a 2003 Z equipped with the TN single turbo kit.
car was running fine , until i had to go with an engine swap (broke a piston ...)
to make a long story short, i can turn on the car but there's no throttle response ( battery and CEL are on but not VDC...)
i used Cipher , ECU is throwing code number :
P2122 Accelerator Pedal Position Sensor
P2128 Accelerator Pedal Position Sensor 2
Also the car is in limp mode since its idling at 1500 RPM.
i already searched the forums, some guys here tried replacing the MAF and TB and they still had the same problem.
i tried to reset the ECU , and still have the same problem...
i checked the wirings, everythins is fine.
so i really don t know what to do !
HELP !
Old Aug 14, 2009 | 04:34 AM
psychoballistic's Avatar
psychoballistic
When you check the wiring, did you pull off the plastic covers around the pins and check for any corrosion of any sort. I went through the TB and APP sensor replacements and had no luck.
I finally cleaned every single pin with a tiny abrasive brush and then put di-electric greade on all connection point, both the ecu and the app sensor connectors, and I have had no problem since.
Old Aug 14, 2009 | 12:19 PM
zerosec's Avatar
zerosec
i'll double check the wirings , hope it works out...
is there any other possible solutions ?
Old Aug 14, 2009 | 03:02 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Have you data log via cipher?
Old Aug 14, 2009 | 05:24 PM
TurboTim's Avatar
TurboTim
Vendor - Former Vendor
Are you running Osiris too? if you upload a corrupt file you wil have no throttle response.
Old Aug 14, 2009 | 05:51 PM
Zivman's Avatar
Zivman
you don't say........
Old Aug 15, 2009 | 02:22 AM
zerosec's Avatar
zerosec
Nop, the car is equipped with an Apexi piggyback.
car was running fine when i bought it , problem started just after the engine swap...
@Chef- J: No ,i didn t log anything using cipher...
Old Aug 15, 2009 | 02:38 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
Sounds like you can simply fix issue via cipher. I'm still figure leaning using cipher. if you not familiar using cipher, ask uprev to walk thru with you. I'm sure jared or rich will happy to help you. Let us know.
Old Aug 15, 2009 | 04:30 AM
zerosec's Avatar
zerosec
i'll see what i can do with cipher
i'll keep up posted
Old Aug 17, 2009 | 12:13 PM
zerosec's Avatar
zerosec
tried everything ...still not working...
