Timrod Belt Layout with extra idler pulley
that is a custom pulley that i made, due to the GTM pulley was pushing the belt out, so that's why i made this custom pulley with walls. then there only will be one way out. tomorrow i'll also change the bottom GTM pulley to the custom i made.
i'll post the pic's and vids tomorrow
Have you looked at stock block TT dynos with similiar peak HP? A strong vortech will overlay most TT's on a stock block. without going to built block, you wont gain much.
for example from this thread https://my350z.com/forum/shop-builds...completed.html
stage 2 GTM is about the same size turbos as Greddy 20g's and bigger than the 18g's for sure.
vs mine
same HP curve means same trq curve. hp=(trq*rpm/5252)
vs mine
Where did you installed GTM pulley at? Mine never push out, it looks it aboutu to, but it just balanced out with other pulley.
the T-trim is rated for 55,000 if he has the V-1. The V-1s use straight cut gears. People have said there are V-2 T-trims with helical gears and those would probably only be 53,000 limit.
I'd just be careful, no warranty on T-trims. so if bearings go, thats $$$ rebuild.
wenlipai,
i sent you a pm about your gtm pulley. do you want to get rid of that gtm pulley or can you get ahold of more of your machined pulleys?
my mod pulley is a 2.5" pulley and i would like to go to a smaller one like the gtm to save some belt room.
i got the GTM pulley out, and made a new one with the same size, and wow 2.5" isn't it too big? the size of both pulley are the same exactly the same size.
ohh, get it, if you do want it, pm me and send me your full address and zip code, i'll get quote by UPS tomorrow. you have paypal right?
