Headwork... DE vs HR flow testing
Old Aug 24, 2009 | 07:54 AM
Cass007's Avatar
Cass007
Default Headwork... DE vs HR flow testing
So here is a thread for those of us that are considering headwork on our VQ's. This is what I am having done to my heads and I will share a general cost (your cost may vary, I'm a repeat customer) and the before and after comparison flow test so you can decide if this mod is worth your duckets.
https://my350z.com/forum/forced-indu...gress-101.html
Posted by Dave @ HeadGames
http://www.headgamesmotorworks.net/
ok...finally some pics for your viewing pleasure! Waited on parts for a bit...
This is how a valve job is performed. Valve job is being performed on a Sunnen SGM1500 seat and guide machine. This machine is what most ProStock shops switched to a few years back. Most of you I am sure have never seen some of this stuff, so feel free to fire questions off.
The Sunnen machines are a fixed pilot machine, meaning the pilot is fixed into the valve guide and the machine centers off of it. This is the pilot with spring
This is a cutter body, and the cutter that makes the valve job. You have heard the 3 angle, 5 angle valve jobs...you can get all 3 or 5 on one cutter or 3 or 4 and make the other angles yourself with cutters.
This is the intake being cut
this pic illustrates the finished angles on the left and no so finished on the right. We are doing this on a stock size valve. Take note, the area under the valve is crucial to flow, as much as the angles. Blending by hand is surely needed to get this right. Going to a oversize valve exasperates this, and few get it right. Bigger is not always better!
this is a typical radius cutter...note the top angle, the 45 or "seat" angle and the radius.
stock exhaust seat....
Radius seat...
Next up...blending, lash, milling and flow testing!!!!!!!!
Old Aug 24, 2009 | 07:59 AM
MDHRZ's Avatar
MDHRZ
Great info. Sub'd.
Old Aug 24, 2009 | 08:26 AM
Vas@Extended's Avatar
Vas@Extended
Vendor - Former Vendor
im IN
Old Aug 24, 2009 | 10:29 AM
HeadGames's Avatar
HeadGames
Thanks Chris!
ok...after the valve job is completed this is what your left with. Now, just a FYI this is not true from anyone who does a valve job. This particular valve job takes a lot of material out in the bowl area, meaning not all valve jobs are created equal. The angles and widths of the angles change or vary from job to job and so does the work involved to make them a enhancement versus just a status ques. This is where flow bench work comes in, and the knowledge of how different angles effect the air.
what your looking for is the material left behind from the bowl cut. It is a angle cut that will be blended into the short side and bowl area. It's the shiny part towards the guide
We take a grinder with a carbide bit to blend it in by hand. Surely not something your local speed shop usually has the knowledge to do correctly..in this arena, it can make or break the gain you could see. Too much and it flows like big cup and too little is like a straw. And their is even some that when blended it doesn't work as well. This is where a flow bench comes in handy!
And this is a side by side comparison...
Same is done to the exhaust side...this helps blend the bowl into the radius, so it is a radius from the short turn to the chamber.
It's then sanded with a 60grit cartridge roll...finished product
next up....lash!
Old Aug 24, 2009 | 11:22 AM
INTENSEPOWER's Avatar
INTENSEPOWER
Thanks for making this this a thread!
Headgames is top notch for sure. Please keep updating this with more technical info as well.
Darren
Old Aug 24, 2009 | 03:24 PM
superchargedg's Avatar
superchargedg
Damn Noobs
I still remember doing this stuff (long back in the day) on small and big block chevys,fords and mopars.
Old Aug 24, 2009 | 04:10 PM
MDHRZ's Avatar
MDHRZ
Nice pics on their site
Old Aug 24, 2009 | 06:46 PM
zman1982's Avatar
zman1982
In for results, awesome thread
Old Aug 24, 2009 | 06:50 PM
ttg35fort's Avatar
ttg35fort
Professional
I'm in for more pics like the one in post #7. Can we get a full body shot, maybe in a short, short skirt and a tube top??? Beter yet, put her in a thong bikinki.
Old Aug 24, 2009 | 08:01 PM
INTENSEPOWER
See! Right there is an example of why HeadGames deserves their own thread! If this was integrated into Cass's thread we'd have more than likely not have been blessed with the link to such a beauty! (the girl ain't that bad either!)
Ahaha
Darren
Old Aug 25, 2009 | 01:29 AM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Glad to see this thread
Old Aug 25, 2009 | 06:45 AM
HeadGames's Avatar
HeadGames
thanks guys..I appreciate the compliments on the work, and the lady. Im a bit busy today, porting a 2J but I will put something up before the end of the day!
Old Aug 25, 2009 | 11:01 AM
GT-Z's Avatar
GT-Z
Nice thread!
Old Aug 25, 2009 | 11:53 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
Awsome!!!
Edit: Just Q, How long it takes to finish? ( headwork )
Old Aug 25, 2009 | 12:04 PM
Philthy's Avatar
Philthy
Boost Junkie
Dave does awesome work and you've made a wise, well informed choice! I'm running HeadGames heads on three cars I currently own, G35, EVO, and STI - all of them have produced crazy gains...!
See Dave at work here... And yes, Dave's hands really do move that fast, no camera tricks or video speed increasing...
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/timSs9XsiEA&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/timSs9XsiEA&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Old Aug 25, 2009 | 12:29 PM
ttg35fort's Avatar
ttg35fort
Professional
Very nice torque curve, Philthy!!!
Old Aug 25, 2009 | 07:17 PM
Italianjoe1's Avatar
Italianjoe1
in for HR before/after numbers
Old Aug 26, 2009 | 08:08 AM
thom000001's Avatar
thom000001
Dave's work is present on the SP shop car as well......9000rpm and still flowin......(manifold is necessary too)
tom
Old Aug 26, 2009 | 11:01 AM
IIQuickSilverII's Avatar
IIQuickSilverII
and turbos... quite a few factors... but of course heads are VERY important
great thread!
Old Aug 26, 2009 | 02:03 PM
Chi-TownWarrior's Avatar
Chi-TownWarrior
In for the HR results
