Vortech ruining AC lines?
My ac stopped blowing cold the other day. So i had a buddy who hooked up the ac system checker and there was a leak. I have a vortech supercharger and the high pressure a/c line is close to the charger itself. There is either a crack or tear or hole that makes the freon leak. Could the vortech do this? Only thing down there is the oil line and i don't think that gets hot enough to put a hole on a metal ac line. Anyone else have this problem?
Also, the mechanic buddy told me it's impossible to get to the ac lines without removing the charger. Is this true or is there no way around it, I have to remove the charger? Thanks
I know a member here ( cheff ) his AC went bad as well... I heat wrapped my AC line twice ever since it happened to em .. and its been perfectly fine.. 90*+. still knock on wood.
Yep. It happend to me, mine was blower hit a A/C line it made a very tiny hole. I Just reweld it and wrapped with heat wrap. So far running hot days no problem.
Really it could happen? WTF how come it doesn't happen to anyone else. Also what did you mean by 90*+ ? Temps here in cali are being ridiculous it's around 90-100 these days during the day. My water temp is hitting 205-210 when it used to hit around 180-190. And I am driving with NO AC, it's driving me crazy.
Oh and no one answered but, could you still get to the ac lines without removing the charger? how did you weld it, jb weld or actual weld weld.
https://my350z.com/forum/forced-indu...ed-my-a-c.html
^haha, can not believe temp was very cooler than now. lol
Happened to me too. The oil line got hot enough to melt a hole through the high pressure line. We tried to weld it and it made the pin size hole pencil size. We ended up cutting it and used a union coupler to fix it. I then wrapped the the line with a rubber hose. So far so good.
Does anyone get heat soak in their AC system? When it's really hot out and I'm going less than 15mph for an extended time or sitting in traffic it starts cycling warm/cold/warm/cold until I'm moving again then it gets REALLY cold again once I'm moving again.
Here. I don't know if it is call A/C heat soak, but i do feel that.
Okay so my leak is coming from under the charger. The main questions now are
can it be accessed without removing the charger?
can the hole be welded shut?
someone mentioned cutting it off and using another pipe source?
someone also mentioned they tried welding it and made a pin hole into a pencil sized hole?
As for the welding you have to use an aluminum welder and if it burns a bigger hole then its too hot. might be leaking out the hose(can get that repaired at a local ac shop). n
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
