Camp 2 (Eco mode)
Old Sep 10, 2009 | 05:52 AM
GreenGoblin's Avatar
GreenGoblin
Default Camp 2 (Eco mode)
I have been trying to set this up correctly and I must be missing something.
My settings are as follows
Nissan2
Eco - 1800
Speed correct - 150.1
Power - 100 (I have not played with that yet, this is on stock setting)
Car weight - 1580
Gas - 2.30
Auto past - on
For some reason my speed will not read anything.... It just stays on zero. Any ideas? to share setting that you are running
Old Sep 10, 2009 | 08:24 AM
ADMAN's Avatar
ADMAN
Um. I'll have to check mine. I had it working.
Old Sep 10, 2009 | 08:25 AM
jonnylaw's Avatar
jonnylaw
Are there any "X"'s for "speed" or "injector" on the CAMP2 application chart for our vehicle? I tried similar settings and put it in past mode, and the cost reads out, but the graph and consumption stays at 0. Hopefully someone who has succesfully had it up and running can chime in with suggestions.
Old Sep 10, 2009 | 08:51 AM
GreenGoblin
Ok just got off the phone with HKS, if you have the cable connected to the fcon you need to unplug the odb2 port and hard wire it in via the instructions in the manual and it will work. I will try this when I go home and let you know how it works out.
It will work for our cars, If I remember correct Jonny you are running vpro also...
Old Sep 10, 2009 | 12:48 PM
jonnylaw's Avatar
jonnylaw
Yes, please let us know if it works. I am also running a vpro. hmm. I have to check the section on hard wiring, I thought this was not recommended on the CAMP2 (was required on the original CAMP system), but if HKS says so, hopefully it will work.
Old Sep 10, 2009 | 12:52 PM
Crom's Avatar
Crom
You want to hardwire it just to get the speedo working ?
Old Sep 10, 2009 | 04:42 PM
GreenGoblin
I was told from the HKS tech that when it is hooked up from the obd2 port and the fcon, it is getting confused for a lack of a better word, because the fcon is feeding it signals and it is trying to read signals from the port as well. They said that it need to be hard wired via the manual which looks like ignition and ground and the fcon tells it the rest.
The reason I am doing it is to try to figure out the speed issue which kills of the eco mode which I wanted to setup for grins.
Old Sep 10, 2009 | 05:02 PM
Crom's Avatar
Crom
I lost the install manual - I'd like to know if other fcon/camp guys are using the OBD port. Thats how I have it connected but I am locked out of that functionality as well. Every once in a while my A/F zero's out on the screen (knock amp is fine) but when I restart
its ok....maybe thats the reason why.
Old Sep 10, 2009 | 06:04 PM
jonnylaw's Avatar
jonnylaw
I'm using the OBDII port with vpro and afk and all optional sensors except egt. No go on the eco mode. It's dissapointing the eco mode doesn't work like this. No mention of the need to hardwire if you have fcon to use eco in the manual, I guess HKS fergot to mention..
Old Sep 10, 2009 | 07:39 PM
GreenGoblin
Well I tired it hard wired and nothing... I unplugged it from the fcon and the speed works no problem. I will call back tomorrow to see what they say.
Old Sep 11, 2009 | 11:36 AM
GreenGoblin
Well the out come is nothing good... I de-pinned the odb2 connector so it would just feed the constant power, ign and ground and not the signal wires... So the fcon is taking care of that.
HKS is stumped they say that it must be something on the v-pro side. That a pin on the harness might need to be changed for it to work with the car, if it will even work period. I am a bit disappointed.
Old Sep 11, 2009 | 02:58 PM
jonnylaw's Avatar
jonnylaw
Wow..speechless. Looks like I'll give a call to HKSUSA and inquire as well. It is a selling point on their website..dissapointing if it does not work. Also, on the application chart, there is no "x" on speed, injector, etc. for our vehicle application, so according to their documentation it should work, even though it sounds like it won't work.
Old Sep 11, 2009 | 05:53 PM
GreenGoblin
Well it does work if it is not connected to the fcon. I tested it out speed works fine As soon as the wire to the fcon is disconnected. Between this and not being able to select different maps on the fcon via camp2 it looks more and more like they dropped the ball.
Old Sep 11, 2009 | 05:59 PM
Glex25's Avatar
Glex25
Between that and not enabling USB function for updating software and possibly pulling logs.
You can't read AFR unless you have a Fcon.
They should had offered a wideband solution for those using it as a standalone or at least a signal input wire for those running aftermarket widebands.
Old Sep 11, 2009 | 06:05 PM
Crom's Avatar
Crom
Not to mention that the cool functionality of the camp only works w/ the (IS) version of the fcon - ala map switching is a complete fail in my book.
Old Jan 24, 2010 | 11:15 AM
jonnylaw's Avatar
jonnylaw
in for any updates? So the eco mode will only work on the camp2 if the vpro is disconnected?
MAsSIVrOOM
Oct 20, 2023 10:50 AM
aarrgghh
May 1, 2022 11:04 AM
Vigman
Nov 17, 2015 04:34 AM
kyin
Oct 15, 2015 05:54 AM
