does vortech rev-up work on non rev-up engine??
Old Sep 17, 2009 | 05:33 PM
sk tam's Avatar
sk tam
Default does vortech rev-up work on non rev-up engine??
hi
i have a 03 z, does vortech rev-up works on 03 z engine???
thx
Old Sep 17, 2009 | 05:37 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
no.
different bracket, belt layout and pulley configuration.
Old Sep 17, 2009 | 06:19 PM
sk tam's Avatar
sk tam
so change the pulley and belt it still won't work??
Old Sep 17, 2009 | 06:24 PM
str8dum1's Avatar
str8dum1
once you change the $500 bracket as well, then it will work
Old Sep 18, 2009 | 04:20 AM
JET MECH's Avatar
JET MECH
if you are going to use the full vortech kit "fuel system components included in full kit" the fmu is calibrated differently from the rev-up to the non revup. also the split second box some of the older rev-up kits came with is only applicable to the the rev-up application. if you are going the tuner kit route than a mounting bracket,cog and serp belt change will be needed. IMO its not worth it, just get the appropriate kit for your application. alot less headaches.......
Old Sep 18, 2009 | 10:42 AM
sk tam's Avatar
sk tam
thx
liqalu04
Jan 2, 2022 12:58 PM
Shane86
Sep 17, 2015 05:33 PM
torchkc
Sep 11, 2015 08:26 PM
