Another Powerlabs DIY and picture diary
Old Nov 11, 2009 | 05:54 PM
  #101
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally Posted by turbociv910
head gaskets pop from detonation.. time for a new tuner
While I agree, with VQs the rods and piston ringlands will go WELL before the headgaskets.
Old Feb 19, 2010 | 06:22 PM
  #102
bikinilust's Avatar
bikinilust
in hein-sight... would it have been easier to have just removed the engine, install what you can, reinstall engine, then button up the remaining tubing? I know it seems like more work to drop the engine, but what u did amazes me that there werent some exhaust leaks. And then getting to those leaks would be a biotch
Old Feb 20, 2010 | 12:37 PM
  #103
jeffie7's Avatar
jeffie7
I did my install on my own in my apartments 1 car garage. There's zero reason to remove the engine. If I had to do it again and had a cherry picker I still wouldn't have remove the engine unless I was planing on doing a clutch while at it.
Old Feb 21, 2010 | 04:12 PM
  #104
z2envy's Avatar
z2envy
^ Don't need to pull. I put mine up on 4 jacks and was able to get under and do what I needed to do. Even installed a clutch/flywheel that way too. Had a tranny jack for that which helped a ton!
Old Feb 22, 2010 | 07:04 PM
  #105
Elperuano's Avatar
Elperuano
This thread rocks, very helpful stuff.
Old Feb 23, 2010 | 09:54 AM
  #106
idanielsan's Avatar
idanielsan
Yep no need to pull engine.
The fitment is very tight but if you do things in the right order you should be fine. I did have some hissing but my tuner cleaned up my bolts (just tightened them) before the dyno and haven't had any probs since.
Old Feb 23, 2010 | 10:13 AM
  #107
Erdem's Avatar
Erdem
subscribed...
Old Jun 4, 2011 | 06:40 PM
  #108
phreaktor's Avatar
phreaktor
Design Engineer
Amazing chronology and photography. You should send this to Powerlabs. A+ write up.
Old Jul 16, 2011 | 07:29 PM
  #109
Itzcashew's Avatar
Itzcashew
Actually pulling the engine would be more of a PITA than helpful. If he put the engine back in and it doesn't fit he has to take everything off and waste time.
Though its hard to get to some area to tighten a screw I think it was a better idea going the way he did so he can make sure what fit where and what not.
Old Aug 11, 2011 | 09:31 PM
  #110
zach711f's Avatar
zach711f
im installing this kit now...worst instructions in my life..i have to go to this thread to figure everything out!
Depravity
Oct 1, 2015 04:49 PM
