Need a little help from my FI friends (EBC and Osiris)
Old Oct 7, 2009 | 12:46 PM
Boozt's Avatar
Boozt
Default Need a little help from my FI friends (EBC and Osiris)
The STS thread has been slow....so I am throwing this out to the FI community at large. I want to swith to the Osiris over the Utec on my STS Z. I can produce 15psi all day but don't know if the injectors (440's) will hold up????? What is my max boost on these injectors??? I also need a suggestion for a reliable EBC.......Then some map help for the Osiris over the base tune. Thanks for the input
Old Oct 7, 2009 | 01:15 PM
str8dum1's Avatar
str8dum1
When you get your Osirus dyno tuned, your tuner will tell you if your injectors are too small as boost does not equal horsepower.
Greddy, HKS etc all make 'reliable' boost controllers. Just depends how much you wanna spend. A simple google search will list all your options.
Old Oct 7, 2009 | 01:22 PM
SmallTuner's Avatar
SmallTuner
1000cc
Old Oct 7, 2009 | 01:25 PM
athenG's Avatar
athenG
Your 440cc will never hold up with 15psi.. heck my DW 440cc can barely support 8psi and that is with 50/50 water/meth.
Old Oct 7, 2009 | 03:19 PM
rcdash's Avatar
rcdash
With the switch to Osiris, you will lose overboost protection, so choose an EBC that has this feature (I think the HKS EVC 6 does, but not certain). Your injector requirements will not change going from a UTEC to Osiris. They are unrelated. That said, 15 psi with any form of FI will likely exceed the safe capabilities of those injectors as others have noted.
Old Oct 7, 2009 | 03:58 PM
Boozt's Avatar
Boozt
Athens....good to hear from you! What do you suggest for injectors so I don't have to tune twice and waste cash on labor time.
Old Oct 7, 2009 | 04:01 PM
Boozt's Avatar
Boozt
I have considered keeping utec with bigger injectors and more boost.....I just don't think the Utec is working all that great for me. Any advice or suggestions is welcome.
Old Oct 7, 2009 | 06:41 PM
str8dum1's Avatar
str8dum1
I run 15-16 psi no problems with a great tune. The resolution is still good, but prolly close to its limits at the range. I'd never go from an active knock system to a reflash, not at that level anyhow.
Without a dyno ,its hard to say what size injectors. My SC at 15 psi is only like 460 hp. A turbo at 15 psi might be well over 500. But either 600 or 800 deatchwerks is what I'd go with.600 if you are close to 450 and 800 if you are over that
Old Oct 8, 2009 | 05:11 AM
Boozt's Avatar
Boozt
Thanks for the input everyone. I obviously need to do more homework.
Old Oct 8, 2009 | 09:55 AM
rcdash's Avatar
rcdash
Sharif's dyno, correct? That 460 hp is probably just over 500 DJ STD whp. Did you ever do a comparo at Staples in Durham?
Old Oct 8, 2009 | 10:44 AM
str8dum1's Avatar
str8dum1
havent been to a DJ yet. Always have something else I need to spend 60+ bucks on This week it was a new axle.
Old Oct 9, 2009 | 05:48 AM
Boozt's Avatar
Boozt
Ok....so my current plan is 600 DW injectors, ebc (any suggestions??) currently running MBC, , possibley meth injection (damn thing runs high EGT's....up to 1300 6th gear on the hwy) and a proper tune at 12-15 psi. Just for background. I'm running the STS kit with a modified garret 60-1 trim, light flywheel with 6 puck clutch, with boost-EGT-and wideband guages.
Old Oct 19, 2009 | 02:28 PM
lope483's Avatar
lope483
if you are upping your injector size, DO NOT keep UTEC. i was having incredible problems after i installed my APS kit with UTEC, 660cc DWs and a 255lph walbro. car would not idle AT ALL. i eventually went with Osiris. have had no problems since. Osiris > dogshit > UTEC imo. look up my other threads in FI to get a good idea of the problems i had with that combo. good luck in w/e you choose though.
Old Oct 19, 2009 | 02:29 PM
lope483's Avatar
lope483
oh yeah, and i have an HKS EVC6 and its amazing. havent even messed with half the features yet but its easily one of the best EBCs ive ever used.
May 30, 2017 03:28 PM
_bit
Oct 2, 2015 07:49 AM
