Procharged Z running too rich
Old Oct 11, 2009 | 07:27 PM
zcar03's Avatar
zcar03
Default Procharged Z running too rich
My car had some old gas in it. Went down to a quater tank and wouldnt start anymore. I added some lucas Cleaner and fillled it up to 3/4 gas with 93. Then still no start. I disconnected the fuel IN line and filled a 2 gal gas contained 3 times to rid of any gas in lines. I replaced it and at the same time took the Piggy Back Procharger fuel pump out.
I have:
ATI Procharger (I just upgraded to a 12PSI setup)
HELIX TEST Pipes, NGK Iridium 1 step colder plugs, 155 Fuel pump,RC440 injectors
I pulled the plugs and they were drenched. I cleaned them all up and then replaced them and the car started right up. It boggs down when I get on it. Also since replacing the fans with some slim ones it was at H temp for a while ( I have to check and see if both fans are turning on). Also at Idle 900RPM I have only 10-15 psi of OIL Pressure.
Any help? I have a greddy emanage I have to hook up. Should I get 2step colder plugs now that boost is 12PSI?
Old Oct 11, 2009 | 07:38 PM
350Z_LEE's Avatar
350Z_LEE
Get a tune.
Old Oct 11, 2009 | 07:45 PM
zcar03's Avatar
zcar03
should I change the plugs to 2 step colder?
Old Oct 11, 2009 | 07:50 PM
Jay'Z's Avatar
Jay'Z
Its going to.....
Old Oct 12, 2009 | 05:17 AM
djamps's Avatar
djamps
No.
Old Oct 12, 2009 | 09:27 AM
Cass007's Avatar
Cass007
I have:
Just so you are aware, my motor showed this twice just prior to BOOM!!
Have the car towed to a shop right away. I know it will be expensive, but so are motors. Better safe than sorry IMO.
Old Oct 12, 2009 | 03:04 PM
zcar03's Avatar
zcar03
Ive been driving it its a little rich
what did it show twice?
Old Oct 12, 2009 | 03:41 PM
Cass007's Avatar
Cass007
10-15psi oil pressure at idle
Old Oct 12, 2009 | 03:54 PM
Jay'Z's Avatar
Jay'Z
Then BOOOOOOOOM!!!!!
Old Oct 15, 2009 | 01:08 AM
gennosuke1's Avatar
gennosuke1
is this caused from not tuning properly?
Old Oct 15, 2009 | 05:37 AM
zcar03's Avatar
zcar03
Probabaly I have an emanage ultimate on the way. Anyone know where I can find a base scharged map.
Old Oct 15, 2009 | 05:54 AM
Jay'Z's Avatar
Jay'Z
Can you not afford to take it to a tuner? Your not sounding too smart about this..... Do it right/safely....
Old Oct 15, 2009 | 07:29 PM
zcar03's Avatar
zcar03
I actually build cars for a living. Id rather do as much as I can and learn and know the program then bring it to a tuner. This will also save money, I dont relaly have much now I dropped another 5k into this car this summer alone - with me doing all the work and paint and 1 off fenders.
Plan on taking to a tuner after I do as much as I can.
Old Oct 15, 2009 | 08:31 PM
350Z400rwhp's Avatar
350Z400rwhp
The low oil pressure would not be caused by a bad tune. If things aren't making sense then I think you are at the point where you have done as much as you can (Tune $300 < $5000 Blown Motor)
Old Oct 15, 2009 | 09:06 PM
Jay'Z's Avatar
Jay'Z
Go ahead then... Save 400-500.. Good you "build cars for a living", NOT tune cars, huge difference.. But I told you SO...
Old Oct 15, 2009 | 10:15 PM
zcar03's Avatar
zcar03
I figure Ill at least hook it up and throw a base map on it and take it to be tuned after.
Old Oct 16, 2009 | 12:35 AM
gennosuke1's Avatar
gennosuke1
since you have a procharger i was wondering, is this kit pretty reliable?
im kinda confused so is procharger a turbo? So it would be legal in cali
dont mean to jack your thread
Old Oct 16, 2009 | 10:28 AM
350Z400rwhp
It is a supercharger. I do know the Vortech Supercharger is legal in Cali. not sure about the Procharger but there is much better avaliablity if you are looking for a Vortech.
apex locator
Jul 23, 2021 02:27 AM
