Twin Turbo build need some help what do u think!!
Old Oct 21, 2009 | 02:15 AM
350z_freak's Avatar
350z_freak
Default Twin Turbo build need some help what do u think!!
ok i am kinda new to the tuner world i have a 03 350z but learning lots day by day i am in iraq and want to get my build straight before i get home ok here it is
GTM 350z DE (Turn Key) Twin Turbo Kit here is the site:http://www.gtmotorsports.com/product...cat=258&page=1 just copy and paste it comes with every thing i need to do that but what i want to know is the engine capable of around 500 hp of which that is goin to bring it to what i have read is the rods r the weak point in the engine i just dont want to be blown the engine on the first drive cuz somthing goes wrong with the engine but if u have anything for me or somthing i can do to the engiine to make it be able to run around 500 HP with no problem. thank u for your time
Old Oct 21, 2009 | 02:38 AM
ttg35fort's Avatar
ttg35fort
Professional
You're stock block will not hold up to 500 hp for long. Running 500 whp on a stock VQ35DE motor is a bad, bad idea. If you want to get to that hp level, you probably should consider getting a built short block. With Eagle rods and Wiseco pistons, they start around $2600 at Import Parts Pro. Since you are already dealing with GTM, maybe they can hook you up with a short block for that price range.
I see you are in Iraq, and may not have a lot of time for research. Nonetheless, you should always do the research before asking a question. You will often find that the answers to your questions are already contained herein. For your research, start here (the g35driver forum is the sister forum to My350Z, both cars have the same motor/drivetrain):
http://g35driver.com/forums/forced-i...-you-push.html
Then look at some of the other builds in both forums to get an idea of what else you need for your hp goal.
On another note, without any punctuation whatsoever, your post is difficult to read. If you keep posting like that in this forum, the flaming will start. Take a little more time to make your posts more legible, and you will generally get better responses to your posts.
Old Oct 21, 2009 | 02:57 AM
350z_freak's Avatar
350z_freak
Thanks a little new to it good advise thank u for your time
Old Oct 21, 2009 | 10:03 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
I say you see how 400whp feels with your GTM kit and you can always put in the built block later.
You will probably want to upgrade the injectors and return fuel system if you plan on building the motor. And if it isn't obvious, the tune.
Old Oct 21, 2009 | 01:39 PM
zerosec's Avatar
zerosec
500 hp on stock block wont be a reliable setup and won't hold much before u blow ur engine....
if you have the money go with forged internals once and for all. do it right the 1st time
Old Oct 21, 2009 | 01:48 PM
dozzer1b's Avatar
dozzer1b
if you dont have the money to build the block, you dont have the money to go FI on these cars. I went through 2 built motors in a span of 20months. Save your money and build the block, because even when there built, there not very reliable
Old Oct 21, 2009 | 05:21 PM
1GR8350Z's Avatar
1GR8350Z
I agree with seeing how 400 hp feels to you. The original block in my car blew in a very short time at 460hp and an agressive tune. Now its at 403hp with a much safer tune and for now I'm content with the power. Not enough emphasis can be put on getting a proper tune.
Old Oct 25, 2009 | 10:33 AM
350z_freak's Avatar
350z_freak
thanks guys ya i think i am goin to just save and build the block u guys helped alot thanks again
