Catch can questions
Old Oct 24, 2009 | 03:15 PM
widerisbetter's Avatar
widerisbetter
Default Catch can questions
I looked everywhere on this forum for a diagram of diff configs for catch cans. Im having blowby issues and want to try some diff ways. Im running a greddy catch can and it has never had a drop of oil in it. The cars seems to burn the rest.
Old Oct 24, 2009 | 07:02 PM
midz350's Avatar
midz350
Here you go:
https://my350z.com/forum/search.php?searchid=10018141
And someone posted this:
Are you wanting to run a vacuum pump based catch can or a recirculation based catch can. You'll need a pair of check valves and to tap into the intake manifold (assume this is where the stock PCV system connects to) with a one way so it doesn't boost into the crank, and put the other one way going into one of (or both) of the pre-turbo pipes. Those two act as your "vacuum source", connect them to a "T" and the output of the T goes to your catch can, which then pulls from the crankcase breather.
Or this may help:
Old Oct 24, 2009 | 07:07 PM
midz350's Avatar
midz350
^^ I'm really bored.
Old Oct 24, 2009 | 07:26 PM
Nate76s's Avatar
Nate76s
I also read that just a can with nothing in it won't catch much. Some guys have been putting some steel wool in their cans to help catch the oil before it can blow bye.
Old Oct 24, 2009 | 09:01 PM
widerisbetter
Thanks Midz350. I found alot of threads but none useful. This helps some Thanks
Old Oct 24, 2009 | 10:22 PM
03threefiftyz's Avatar
03threefiftyz
I made one out of an air/oil separator meant for an air compressor that I bought from Lowes.....took about 20 mins. It catches oil........I too have some blow bye issues. The only thing is you have to plug up the lower nipple deal because it can't hold the pressure for some reason.
Pic: (made it kinda big)
Edit: One thing though is this set-up only holds about 1/4-1/5 the volume of the greddy......so you have to check it more regularly.
apex locator
Jul 23, 2021 02:27 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
