Built Motor + Greddy Twins + Osiris = A good idea?
Old Nov 1, 2009 | 02:52 PM
  #41
rcdash's Avatar
rcdash
Originally Posted by SOLO-350Z
No product will protect for knock above 5000 rpms as the engine is creating a ton of noise already and the little microphone (which is what it is) will no longer pick it up. This has been said many times before. UPREV has protection up to 5k rpms.
I personally know someone who just got Haltech and now he is ditching it for UPREV because of constant issues with drive ability he has had with his car.
He should ditch his tuner first. LOL. I hope it's not the same tuner that's going to try to tune Osiris, because it is not nearly as intuitive as the Haltech. Sorry if the truth hurts bud, but that's the way it is. UpRev has done a great job considering all the reverse engineering, but when it comes down to it, the driveability of a car with any of the standalone fuel, timing EMS systems (Osiris included) will only be as good as that dictated by the experience level of the tuner and the effort put into it.
Overboost is a real concern and it would preclude me from using Osiris without something to address this. Just because it hasn't happened to you, doesn't mean it won't happen to someone else. On the Haltech, overboost is implemented with a fuel cut. Fueling resumes when boost drops back to a predetermined value. Not sure about the FCON.
You guys realize that all you need is a hose melting, coming off or developing a leak (going to the boost controller or wastegate) to have overboost that WILL destroy the motor?
Old Nov 1, 2009 | 02:54 PM
  #42
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Old Nov 1, 2009 | 03:03 PM
  #43
Resmarted's Avatar
Resmarted
haltech, aem, motec >all
piggy back world utec and power fc are the two top dogs...
Old Nov 1, 2009 | 03:05 PM
  #44
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
^^ Keep thinking that.
Old Nov 1, 2009 | 03:17 PM
  #45
rcdash's Avatar
rcdash
Originally Posted by westpak
I agree a well setup system should not overboost not sure where that comes from, I have not had any overboost issues in 5 years of boosting my Z.
The Fcon cannot control overboost, but if you have some failure of a component that results in overboost the best safeguard is to have the fuel map dump a ton of fuel at boost levels above where you want to run and you can also do the same with the timing maps, you can reduce the timing at the same levels as the fuel dump.
A good boost controller should cover the issue, but to be safe making the fuel and timing changes I mentioned is a safeguard
This is just nuts. The FCON has no overboost failsafe? Yikes. When I was hooking up my boost solenoid, I was thankful that the Haltech had overboost protection. The knock issue I can understand and usually if you're going to get knock it will be most relevant at peak torque, which is under 5k.
Old Nov 1, 2009 | 03:42 PM
  #46
ttg35fort's Avatar
ttg35fort
Professional
Raj, I'm not so sure about this. I just looked at the installation drawing for a Tial WG and for the HKS EVC. If the line coming from the intake side comes off, your boost will drop down to spring pressure. The only way I can see overboost occuring is if there is a problem in the boost controller itself.
I don't recall ever seeing a serious overboost problem being posted in the forum. I have seen boost creep, but that is a different issue altogether. I have seen that on Greddy turbos running high boost without a W/G relocation kit.
Not to say that overboost protection would not be a nice feature, but I don't see it as being absolutely necessary. Other than the Haltech, which EMS's actually provide this specific feature? The F-CON doesn't.
Old Nov 1, 2009 | 03:44 PM
  #47
Chef-J's Avatar
Chef-J
Booooosstt!!
Out.
Old Nov 1, 2009 | 07:09 PM
  #48
rcdash's Avatar
rcdash
What if you accidentally connect your atmosphere port to boost and vice versa? Now that I think about it with external wastegates you may be ok with a hose coming off. With internal wastegates, the situation is reversed. Maybe I'm just paranoid, but preparing for the worst can help prevent disasters, right? What if your stepper motor fails, a wire becomes unplugged from the boost controller, or a fuse blows that was feeding the boost controller? What if your wastegate actuator fails?
While I concur the risks are low, and it might not occur for any given individual, to say that it cannot happen based solely on personal experience, is bit of a stretch. I know westpak has alot of experience, but still.
If it ever does happen, you'll be thankful that you've got protection. I have encountered boost cut, when going from closed loop to open loop on the dyno. My open loop tune was configured during the summer. I ran the same open loop #s in cool weather and I hit 16.5 psi. The Haltech shut it down hard at that point. It all happened so fast, there is no way I would've recognized it quickly enough to shut down. Not that I would've blown the motor going to 17 or 18 (I don't think, as the map is tuned ultra conservative in that area).
While the FCON may not have overboost cut, I believe the EVC VI has an overboost alarm. You may want to set that up.
Old Nov 1, 2009 | 07:14 PM
  #49
ttg35fort's Avatar
ttg35fort
Professional
No matter what, a spring should be used. If the boost controller is properly designed, it should not maintain boost pressure beyond the spring rating if any of these things occur. For example, my safety mechanism on my meth/water injection system is to disconnect the ground from my boost controller if the meth/water tank runs dry. As soon as power is disconnected, the boost immediately drops to around 8 psi, which is what the springs are rated for. The same thing will happen if the fuse blows.
Have you heard of the overboost problem actually occuring on somebody's car? Any threads that you can post links to?
Old Nov 1, 2009 | 07:19 PM
  #50
str8dum1's Avatar
str8dum1
15$ and make your own overboost protection
with this
http://www.aquastealth.com/pressureswitch.aspx
and a solenoid to vent the wastegate.
or you can wire that switch up to your coil wire and kill your spark like they did here
http://www.nicoclub.com/articles.php?id=158778
Old Nov 1, 2009 | 07:25 PM
  #51
ttg35fort's Avatar
ttg35fort
Professional
Nice find, Rich.
Old Nov 1, 2009 | 07:37 PM
  #52
rcdash's Avatar
rcdash
Terry, I have not heard of an issue on my350z. This is the only forum I have time to really keep up with though.
str8dum1, it's nice to have some kind of protection, even if it is a little extra headache. I know most OEM turbo cars have some kind of overboost failsafe - if nothing else a pop off valve...
Old Nov 1, 2009 | 09:21 PM
  #53
350Z400rwhp's Avatar
350Z400rwhp
Most OEM turbo cars have a boost sensor that cuts timing or fuel during an event of overboost. Back in the day I can remember having to fool this unit by crimping the vacuum line or a bypass harness when I turned up the boost on my MR-2, RX-7 and Eagle Talon Turboed cars.
Old Nov 1, 2009 | 10:07 PM
  #54
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
Exclamation
If one were running just on spring pressure, say 7psi, with no EBC, and the line melted or popped off, you would overboost. You need that boost reference from the compressor to the lower port, to help open the gate. Remember, for example, that 7psi at the intake manifold does not necessarily equal 7psi of exhaust pressure at the wategate.
A "good boost controller", as has been mentioned previously, has no way of cutting fuel/ignition in the case of overboost. Score one for the Haltech
Old Nov 1, 2009 | 11:23 PM
  #55
Resmarted's Avatar
Resmarted
Originally Posted by Chef-J
Out.
I don't know what this means, but watevs (im guessing you disagree with my opinion but that is to be expected, im a dumbass in my own right)
I have never heard (or read online) horror stories of cars over-boosting, worst i've heard of is cars creeping so badly they detonate on the dyno (silly hondas!). but that is about wastegate sizing...
Besides looking at our kits, what kit doesn't have wastegates with low psi springs for our cars? If your bc fails you wont overboost....
so imo overboost protection is a cherry on top feature.
EDIT:
g35tt said almost exactly the same s*** lol
Old Nov 2, 2009 | 03:32 AM
  #56
Chef-J's Avatar
Chef-J
Booooosstt!!
^yes. I do disagree with your list. Lol@Just throwing out top brand name. But everyone has diff taste. So forget it.
Op, osiris isn't bad idea, I havent really heard any complain about dyno flash ECU(osiris or technosquare). But its all comes down to what your friend and his tuner feels safe to go with. Defi, I will skip the piggy system for sure.
For the price, osiris will cheaper than standalone. But if there is used haltech ems, I think it won't be much diff.
Standalone or reflash, either way he will be happy with it. Good luck.
Editp, you had rx7? Was FD? Or FC? If was an FD, can I shoot you a pm?
Old Nov 2, 2009 | 05:47 AM
  #57
ttg35fort's Avatar
ttg35fort
Professional
Hi Chris. I again looked at the HKS EVC installation diagram. If the lower line popped off, the pressure in both the lower line and upper line would drop significantly (they are usually connected with a "T", so disconnecting the lower line will bleed pressure from the upper line). Thus, pressure applied to the top of the poppet valve should decrease significantly, which should take it almost back down almost to spring pressure. I have heard of people using spring pressure alone without a boost controller, so I would think that this situation would be somewhat synonymous.
Old Nov 2, 2009 | 05:59 AM
  #58
westpak's Avatar
westpak
SFZCC
I am just saying that my e01 can be set up to cut boost if it exceeds a programmed setting, is that a "good boost controller"
Old Nov 2, 2009 | 06:06 AM
  #59
Chris@FsP's Avatar
Chris@FsP
gotcha.
Old Nov 2, 2009 | 06:22 AM
  #60
Chris@FsP's Avatar
Chris@FsP
I see what you are saying, but it doesn't work like that. Without that lower line connected, there is no boost signal to overcome the force of the spring, therefore the gate would remain closed until boost built up so much that the exhaust pressure itself started to open the gate, but by that time you've most likely doubled your desired boost pressure.
