Glex25 Winter Build
Old Nov 25, 2009 | 10:42 AM
1cockyZ's Avatar
1cockyZ
I saw the block all bored and honed already today when I dropped off the heads. I asked if he could put the block in the washing machine to make it sparkle. He said he was checking out the crank next. Hopefully not an ati dampener but a fluidampr but thats an entirely different conversation.
Old Nov 25, 2009 | 02:14 PM
str8dum1's Avatar
str8dum1
^conversation that there is something wrong with the ATI dampener? The same one that Injected and Sound Performance use in their race cars?
Old Nov 25, 2009 | 03:46 PM
1cockyZ's Avatar
1cockyZ
Nothing "wrong with it". Its overdrives the alt, ps. Do you know the ati dampenr is actually tunable? The fluidampr by design can dampen a broader range of harmonics than the ati without alteration. I have had both and prefer the fluidampr, just because its on somebodies racecar doesn't mean its the best for the application. That kind of thinking isn't ideal. He does track days do you think spinning the ps pump 10-15% faster is a good thing? Cavitation isn't good. Both are great products its like picking which supermodel to take home from the bar...if only all us had that option.
Old Nov 25, 2009 | 06:11 PM
str8dum1's Avatar
str8dum1
track cars dont use power steering anyhow
but point taken. It is quite bigger than stock, 3/4" i think. I'd be interested to see the paper that shows that the PS pump will cavitate by using a larger crank pulley.
I dont know about you, but after enough beers every chick i bring home from the bar is a supermodel!
Old Nov 26, 2009 | 07:13 AM
1cockyZ's Avatar
1cockyZ
Ok I am not absolutely sure about the cavitation but how bout this angle. The higher the rpm the more heat generated so the faster the belt is spinning as well as the pump spinning faster hotter ps fluid in a car that is known for boiling fluid stock. Anyway fighting heat is part of this build with HR headgaskets, pathfinder cooling mod, and the R core koyo. Giovanni did his homework for this.
Old Nov 26, 2009 | 08:18 AM
str8dum1's Avatar
str8dum1
none of those mods will help the power steering from boiling
did you modify the HR headgasket properly to open the stock cooling passages?
Old Nov 26, 2009 | 09:09 AM
Glex25's Avatar
Glex25
We haven't even gotten to that part yet.
We just took the block apart 2 days ago and dropped it off at machine shop.
they will do the necessary cut on the block for the HR headgasket.
Our cars come from factory with a power steering cooler if that becomes a issue I will just get a bigger cooler.
Right now I'm more concerned about the crank and waiting to hear back from the machine shop on that situation. Holiday's don't really help on getting information quickly.
Old Nov 26, 2009 | 09:31 AM
str8dum1's Avatar
str8dum1
ya i was really just tryin to figure out what real world data there was on why a larger crank pulley would be bad becuase I had never seen such info and 1cockyz had.
ya good luck gettin anything done between xmas and new years.
Old Dec 1, 2009 | 05:28 PM
Glex25's Avatar
Glex25
Been cleaning mating surface of the upper oil pan/rear timing cover/front timing cover.
For the ones that have done this
What have you used to cleaned out all the silicone?
Any solvents?
I can remove the large pieces when I was cleaning most of the parts in gas
but the small crevice I have used a plastic spackling spatula which still leaves a slight amount of silicone behind.
I'm thinking a plastic hard bristle brush with gas but wanted to see if anyone had any better ideas.
Old Dec 1, 2009 | 06:24 PM
GreenGoblin's Avatar
GreenGoblin
I use a razor blade and gasket remover and drag the blade at a 45 degree angle.
Old Dec 1, 2009 | 08:31 PM
str8dum1's Avatar
str8dum1
^ that and then scrub with scotch brite pad with some brake cleaner.
Old Dec 2, 2009 | 08:02 AM
arizzee's Avatar
arizzee
Any solvents?
lacquer thinner is a good solvent to cut silicone. a shop rag and elbow grease does the trick - just wear gloves
good luck with the build.
Old Dec 3, 2009 | 05:12 AM
Glex25's Avatar
Glex25
I think that is as good as it's going to get.
I was doing this last night with the garage door open and then a storm came in and had to
close the garage door, I still smell like gas today lol
I still have some gasket material in the throughput holes on the upper oil pan.
I'm going to try some acetone on a small film of gasket material I still have on the lower oil pan.
Anyone seen the white gasket material the factory uses on the lower oil pan? ewwww
Ordered a Crank from Vinnyten
Right now it's just a waiting game on the machine shop
Old Dec 3, 2009 | 06:12 AM
str8dum1's Avatar
str8dum1
billet crank or just a stocker?
Old Dec 3, 2009 | 06:16 AM
Glex25's Avatar
Glex25
Didn't even know there was a Billet crank for the VQ35DE unless your stroking the motor.
I ordered a stock crank.
Old Dec 3, 2009 | 05:28 PM
rrmedicx's Avatar
rrmedicx
Would that be the Cosworth Billet Crank? or is there another? I know BC also makes one, then of course there is the GTM version.
Old Dec 5, 2009 | 04:22 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
Awsome! Good luck!
Old Dec 5, 2009 | 07:54 PM
  #38
rrmedicx's Avatar
rrmedicx
Bump for updates Glen.
Old Dec 6, 2009 | 09:28 AM
  #39
Glex25's Avatar
Glex25
No updates
Crank shipped on Friday
Waiting to hear on M2race to let me know measurements
so I will know which Calico bearings I need to order so they can do
the final balance.
Old Dec 14, 2009 | 06:36 PM
  #40
Glex25's Avatar
Glex25
I was putting mine together today and I cut the pipe as it was noted in this thread thanks
I spent the whole day trying to find a proper plug for the bypass even a barbed fitting I didn't care I found none. The 1/4 NPT or COMP plugs would not fit. The only plug that would fit was some elbows and T's that had 1/4 MPT. I finally went to NAPA and they had a NPT plug which seems to have a little play but it feels tight once it screwed all the way down.
Can anyone shed any light on this conundrum.
I still have to pickup the pressure collars for the tube that goes from the T-Housing to the Plate and weld the small pipe closed.
Here are some pics so people can get a idea
For the guys that went from a FI'd stock compression motor tuned with a Haltech to a FI'd lower compression motor.
Did you guys have to retune for the lower compression motor?
did you wait until after the break in(No Boost, 4000RPM Limiter enabled)?
Will the Haltech automatically compensate for a tune that was made with 600cc if you change them out for a 800CC and you change the injector size in the proper tables?
Might get the call tomorrow to pick up the block/heads from M2race
