Longevity of full builds, the good the bad
Old Dec 14, 2009 | 08:56 AM
  #141
thom000001's Avatar
thom000001
Shoot me the info on where to send it and whatnot and I'll send mine in after the next oil change (prolly won't happen till spring of course since its winter in chicago now)
Tom
Originally Posted by Alberto
Last analysis says they thought coolant was
getting into oil.
BUT-I run Evans which I understand is asn oil based "coolant" so they may be seeing non standard attributes in my oil thinking I run regular coolant. This is why I have asked and asked everyone with built motors to spend $15 on this and SHARE the results. Over a couple months we could have MANY samples and see what is normal or what isnt.
But it wont happen, everybody wants info nobody is willing to share....
Old Dec 14, 2009 | 09:03 AM
  #142
Nealoc187's Avatar
Nealoc187
evans is propylene glycol coolant rather than ethylene glycol coolant I think that's the difference you're talking about. it's still an alcohol but it's not mixed with water like most coolant is.
Old Dec 14, 2009 | 09:13 AM
  #143
Alberto's Avatar
Alberto
Cranky FI Owner
Tom - here you go
http://www.blackstone-labs.com/
Old Dec 14, 2009 | 09:19 AM
  #144
Zivman's Avatar
Zivman
Originally Posted by Old School
I change the oil. Just put in a carbonetics triple and changed the tranny fluid. Recently she's been trying to get hot (last two times i've driven her). Either have air in teh cooling system or my thermo is going bad. Other than that, I beat on her everytime I drive her....and she takes it willingly.
That's how it starts.... pray it is just air. If I were a betting man, I would say the start of something more serious, but I will keep my fingers crossed for ya
Old Dec 14, 2009 | 09:35 AM
  #145
Old School's Avatar
Old School
Shift_Boost
lets hope its nothing serious. started happening when i drove her to show the car at autorama. And i was driving like everyone else on the road. Not really in boost at all. that's what leads me to believe its air. Still gotta check the coolant hose to see if the thermo is opening.
Old Dec 14, 2009 | 10:04 AM
  #146
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
I just had a TT in here w/ overheating problems, and it turned out to be just a bad stat.
Old Dec 14, 2009 | 10:09 AM
  #147
Alberto's Avatar
Alberto
Cranky FI Owner
Put the heat on full hot, full blast, is it cool or barely warm? If so, it is air in the cooling system.
Old Dec 14, 2009 | 10:38 AM
  #148
Cass007's Avatar
Cass007
Last analysis says they thought coolant was getting into oil.
Berto - I will share mie when it comes back this next time. I will be changing the oil shortly as I think the 15/50 I'm running is way too thick for the winter. I plan on sending the oil out every time its changed for the same reasons you do it
Old Dec 14, 2009 | 10:53 AM
  #149
str8dum1's Avatar
str8dum1
do you guys send in your '1st start break in' oil or do you wait til the next change?
Old Dec 14, 2009 | 11:00 AM
  #150
Old School's Avatar
Old School
Shift_Boost
yes sir.
Old Dec 14, 2009 | 11:49 AM
  #151
Alberto's Avatar
Alberto
Cranky FI Owner
I sent in my first one (second on motor) and every one after that.
OS-pick up a spill funnel to let the air out of the system if you havent already. Makes it an easy, clean job.
Old Dec 14, 2009 | 12:18 PM
  #152
str8dum1's Avatar
str8dum1
ok, so i'll send in my dino break in sample and go from there. thanks!
Old Dec 14, 2009 | 12:44 PM
  #153
alan21's Avatar
alan21
alberto i used normal oil for the first 2000 miles to break it in(changed oil after first startup, then at 500,1000 and 2000 miles) and since then I change the oil every 3000 miles with 0w40 mobil one full synthetic (per sam at GTM instructions) I also add Lucus heavy duty oil stabilizer (this stuff is awesome). I also use a mobil one M-110 oil filter (longer filter). I dont mind sending you my samples. My email is alan021@aol.com just email and ill get them out to you.
Old Dec 14, 2009 | 01:34 PM
  #154
streetzlegend's Avatar
streetzlegend
I am sending my sample tomorrow and will be posting the results once i get them back. its going to be my first analysis, so I am a little nervous, its like doing blood lab work and being anxious about the results lol. It might not be the ideal comparison for you since im no where near your power level's (just in the low 400's for now), but at least you'll have something to compare.
Old Dec 14, 2009 | 08:21 PM
  #155
phunk's Avatar
phunk
CJ Motorsports
ive been fortunate.
573rwhp at 14psi, dynojet. never dynoed at higher boost, probably never made much if any more.
problems:
built the motor with a AEBS sleeved block in early 04. first time off the dyno the headgaskets were done. I continued to drive the car and fill the coolant for the rest of the season, but it was annoying as hell and very bothersome.
rebuilt it with a non sleeved block for 2005. probably have almost 20,000 miles on that build, hard to say i havent seen the odometer in a while. problems since:
cracked a 3 exhaust manifolds, sucks because you lose power.
burned out one or two wastegate gaskets.
my biggest drama night; PS belt on my custom belt setup half shredded 2 years ago, the shredded part whipping around wacked my oil pressure sensor wire, made me think i lost oil pressure because gauge went to zero. changed belt and fixed wire, problem solved.
rear main seal drips... replaced it twice, no idea WTF... gave up trying to fix it because its a really slow drip and a huge ***** to fix... ill take care of it with the next build.
APS dual 3" rattled on the crossbrace really bad... welded up 2 additional exhaust hangers to the small V brace in the driveshaft tunnel, fixed it perfect.
last summer i started getting an occasional puff of oil, motor is probably finally a little tired since its just my fun car and only sees abuse.
5th gear has had a scratch forrrrever, its a really old trans. still lets me powershift every gear other than 5th with no drama. i cannot believe 3rd hasnt broken yet since i powershift all the time and the trans was warrentied when the car was still new, so its seen all my stock block abuse AND built motor abuse with no trouble, mostly on R compound tires too.
notes; never broken a single part since the original AEBS sleeved block headgasket failure unless you count the oil pressure sensor wire. its not the original trans but it was warriented before the car was ever boosted, in 2003. im still on original factory clicking axles. car has never left me on the side of the road once. its had a couple quirks as listed above, but so far its been as reliable as anything stock ive owned. i havent really even retuned it in years... i just play with my fuel pressure here and there... every now and then i whip out the laptop and play around, but i havent touched the timing map or main fuel map in years.
last annoyance complaint... i have this damn bizarre RPM studder if i hold 3000rpm at very low throttle, nothing in my fcon/wideband logging shows abnormal. had it for 2 years now. this is actually the main reason i play with the laptop here and there, trying to figure out / correct this.
Old Dec 14, 2009 | 08:42 PM
  #156
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally Posted by phunk
ive been fortunate.
problems:
Lets get it on the dragstrip and I'll show you how to break 3rd AND your stock axles
Old Dec 14, 2009 | 10:27 PM
  #157
acg's Avatar
acg
1. 1/5/08- almost 2 years
2. Miles on built motor - 53,000
3. HP, TQ, PSI - GTM dyno pulled 453hp and 510tq @ 14 psi
4. Motor - GTM (Wiseco Extreme pistons, Carillo rods)
5. Issues -Replaced Fcon once as water leaked onto system from shop not installing a rubber gromet back properly.
Old Dec 15, 2009 | 04:13 AM
  #158
Alberto's Avatar
Alberto
Cranky FI Owner
ACG-thats awesome you have so many miles on your setup, you reminded me of something I forgot to post about.
I one time almost had to replace my Haltech. Same problem the grommet up by the pass side windshield wipers was missing - apparently they fly off with no warning and water soaked the Haltech's wiring for 2 days. Car wouldnt start and if it did it the tach would go NUTS and no throttle response. Ray @ PFS was able to save it for me. Make sure that grommet is in there guys, dumb way to spend $$$ on another EMS.
Also forgot my first oil change I filled it to 6qts (stock + spacer) but that led to start up smoking at idle-was pretty embarrassing showing off the new build and my car is smoking like a dragons a$$hole Let it burn out and knew from then on even with the spacer do not fill to capacity I keep my oil between 5-5.5qts, no issues since.
Cracked passenger side exhaust manifold-replaced under warranty when first build blew.
Grenaded transmission on a 2-3 shift at the track at a measly 525whp - forgot if I had mentioned that or not, you guys have prolly laughed at the vid.
Old Dec 15, 2009 | 04:59 AM
  #159
BrianLG35C's Avatar
BrianLG35C
On your sig. you have more hp/trq noted, what's the psi at? Are you running heads and/or cams?
Old Dec 15, 2009 | 06:12 AM
  #160
alan21's Avatar
alan21
I wanted to add that awhile back I talked to shariff@forged about his 3.8L setup(darton sleeved with 100mm overbore) because I wanted some first hand experience with some who has run the same setup. He stated that he ran it hard for over 20,000 miles (600++ horsepower and alot of track time). Then he decided to go a different route so he disassembled the motor and there were no signs of anything wrong, the motor was in perfect operating order.
