Vortech blower casing differences
Old Dec 27, 2009 | 08:47 PM
350z006's Avatar
350z006
Default Vortech blower casing differences
A year ago when I first got my SI trim blower I tried to swap the impeller cover of my Sc trim with the SI trim, since my Sc Vortech kit came with the shiny finish while my SI trim blower came with the dull finish.
What I discovered was that the Sc trim cover was TOO SMALL for the SI impeller, so when tried to seal the Sc impeller cover over the SI impeller the SI impeller stopped turning; which means that the SI trim impeller cover is slightly bigger than the Sc trim impeller cover. So I put everything in its original configuration after that.
So now I have my new 928 impeller installed on my original Sc trim blower, hoping for greater things than my SI trim. I've read in previous posts that no matter how great an aftermarket impeller is, it will never match the T-trim blower because the inlet/impeller cover of the T-trim is bigger and will allow more air to flow, therefore more cfm/boost generated, more hp,etc...
So now what I'm wondering is, if I go ahead and use my bigger SI trim impeller cover on my 928 blower setup, will to perform better than if I use my original smaller Sc trim cover?
For that matter, let me go to the extreme here; if (I have no idea if this is even feasible) the even bigger T-trim impeller cover would bolt on over the Sc trim blower, would it perform better?
Old Dec 27, 2009 | 11:13 PM
tylerxfire's Avatar
tylerxfire
thats a deep thought my man...good luck
Old Dec 28, 2009 | 03:52 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
I agree with you tyler...
Old Dec 28, 2009 | 04:50 AM
booger's Avatar
booger
Just get a T-trim blower and solve all the head aches
Old Dec 28, 2009 | 05:30 AM
Jay'Z's Avatar
Jay'Z
This should be in Vortech FAQ.....
Old Dec 28, 2009 | 05:41 AM
350z006's Avatar
350z006
I would if the T-trim had a carb #...my trick is that the CARB number is located on the gear assembly of the blower, not on the the impeller cover...nor will they see my bigger injectors, walbro, and hopefully not notice my 2.87 pulley...
I live in socal, and cops don't like cars like mine...
Old Dec 28, 2009 | 08:36 AM
- bigc -'s Avatar
- bigc -
+1 for socal cops hating everything but stock parts...unless of course its on their car then its fine.
350Z_Al
Oct 29, 2020 07:44 PM
350z82
Oct 1, 2015 06:25 PM
