Going to the dark side!!
Old Jan 12, 2010 | 04:10 PM
Barnabas's Avatar
Barnabas
National Z Club President
Originally Posted by djamps
Sounds like you've got everything covered supporting mods wise! Don't settle for less than 400whp DJ with a good conservative tune.
it will be on a DJ for some reason the number 430 is what im expecting... Not sure why but thats my guess
Old Jan 12, 2010 | 04:13 PM
SlideFox's Avatar
SlideFox
Interested to see the final product
Old Jan 12, 2010 | 04:45 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
Looks good. I have a set of used 680cc injectors they used to be ibkarlitos I never used them they are boxed up ready to ship CHEAP ($350)if you want them.
Old Jan 12, 2010 | 04:49 PM
Barnabas's Avatar
Barnabas
will have to talk to my installer about using those injectors, Ill let you know.
Old Jan 12, 2010 | 04:54 PM
03threefiftyz's Avatar
03threefiftyz
Barney.....buy my welds/dr's . Going to need some traction now.
*shameless plug .
Old Jan 12, 2010 | 04:57 PM
Barnabas's Avatar
Barnabas
I would liek too but no way will they fit over my BBK when it goes on. So i would only be able to use them if I keep my rear brakes stock.
Old Jan 12, 2010 | 05:05 PM
03threefiftyz
True . What BBK are you going to get?
Old Jan 12, 2010 | 05:06 PM
Barnabas's Avatar
Barnabas
not decided yet possibly the akebono
Old Jan 12, 2010 | 06:34 PM
djamps's Avatar
djamps
Well I ended up with more than I hoped for... always aim lower and be suprised when it comes out higher . In the end the area under the Tq curve is what moves the butt dyno and wins races With your BB turbos you should have lots of low end Tq.
Old Jan 12, 2010 | 06:37 PM
djamps's Avatar
djamps
Oh don't forget the boost controller since you mentioned wanting to run different boost levels rather than stick to waste gate pressure. EVC6 rocks. Also consider external wastegates (open or not), its the only thing I would have done differently.
Old Jan 12, 2010 | 06:42 PM
03threefiftyz
New tune?
Old Jan 12, 2010 | 06:46 PM
Barnabas's Avatar
Barnabas
I was considering the greddy boost controllor which one is that???
i have externals im pretty sure ill double check with frank
the 550 is the same kit frank is running on his car and he has allot of experience with it soooo im looking for it to turn out pretty sick!!
Old Jan 12, 2010 | 07:13 PM
str8dum1's Avatar
str8dum1
JWT are internal gates. dont have an option there. I dont even think the 850BB kit has external gates Just not an option with JWT.
You can make any HP you want, just play with the boost. You want 430, no reason you cant get 430.
Old Jan 12, 2010 | 07:50 PM
Sylvan Lake V35
If Frank Hill is doing your install he will know the injectors, he did Karls (ibkarlito) work as well. I am in no hurry to sell them they are not advertised but if you want them let me know they are HKS 680cc with the clips i paid Karl $500 for them but they have just been sitting in my garage since I ended up going with 1000cc injectors so just to get they out of my garage $350 shipped and they are yours. Also if ou have not yet bought the JWT 530bb kit I would buy the 700bb kit. It gives you room to grow I bought the 530bb kit myself and once you get a built engine you will find the 530 kit limits you way to much the 700 kit would be a better option IMO. To upgrade after the fact you have to buy new turbos and one new manifold I think it was over $2500 but to buy the 700bb the first time is only $800-1000 if I recall right. Also upgrade the fuel pump from 190 to a 255, i think JWT does that for a few extra bucks. Just a few things I regretted when i did my first build.
Old Jan 12, 2010 | 08:21 PM
Barnabas's Avatar
Barnabas
thank you for the insight on the waste gates
As far as HP goes I have no goal there. I just want a solid tune that I can run at the track and not have to worry too much. So no higher then 9 psi max and if I remember correctly form talking to the tuner not *advancing the timing* and running it slightly on the rich side so to be sure the engine isnt having any extra stress...
My goal is to have as reliable a set up as you can have when FI on this platform.
Old Jan 12, 2010 | 08:23 PM
Barnabas's Avatar
Barnabas
Yes it is frank Hill, I already have the turbo kit the fuel will be a return fuel system. I may be picking up a cjm stage 1 so if I get that then it will be a walbro 255. I am running 600cc injectors with a return fuel setup soo we can be sure to keep steady fuel pressure at all boost, and RPM levels.
Old Jan 13, 2010 | 05:38 AM
tylerxfire's Avatar
tylerxfire
as long as the tune is solid thats all that matters...congrats on it man, get it done and done right....as far as numbers if its going on that dyno at churche's or whatever im sure it will be a high number, that dyno is pretty inflated for numbers from everything ive seen
Old Jan 13, 2010 | 07:08 AM
  #38
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Great looking car, and welcome to FI.
Old Jan 13, 2010 | 07:16 AM
  #39
Barnabas's Avatar
Barnabas
its being done on a dynojet same as the function tuned heartbreaker so im not expecting high numbers at all
Old Jan 13, 2010 | 07:17 AM
  #40
Barnabas's Avatar
Barnabas
thanks sharif!! Frank should actually be talking to you soon about some parts for my car
