Pressurized Cooling System- F/I benefits??
Old Mar 12, 2010 | 06:04 PM
xzotklr's Avatar
xzotklr
Default Pressurized Cooling System- F/I benefits??
I have been researching different cooling systems & solutions and came across a company called C&R Racing that makes a "Pressurized Cooling System''. Seems it is intended to increase the pressure in the radiator, thereby allowing higher temperatures.
According to the company's website:
"The pressurized cooling system controls what happens when temperature rises and water expands.
It is equipped with a pressure accumulator that controls air space and acts as an “air spring”.
At expansion the “air spring” collapses rather than pushing water out of the radiator cap.
A pressure relief valve replaces the radiator cap in this application. The benefits include higher operating temperatures and smaller duct work openings resulting in greater control of water contact in critical areas of the engine.
The pressurized cooling system is used by IndyCars®, Formula One and NASCAR®. The system is adaptable to any water-cooled racecar."
Anyone able to explain the theory behind this?? Would this be helpful for an F/I engine??
Old Mar 12, 2010 | 06:24 PM
Sylvan Lake V35's Avatar
Sylvan Lake V35
Boiling point increases with pressure increases up to the critical point when gas and liquid properties become identical. So i dont much about the system you are asking about but that is theory behind it.
Old Mar 13, 2010 | 05:42 PM
xzotklr's Avatar
xzotklr
Seems this is used in racing applications, but I'm not sure if this would be useful on the street.
Old Mar 14, 2010 | 12:32 PM
BrazenZ's Avatar
BrazenZ
It lets you run higher coolant temps so that your radiator doesn't boil over which is a good thing. The problem is It doesn't bring down the coolent temp down either so it make it useless in street car.
Old Mar 14, 2010 | 04:43 PM
KornerCarver's Avatar
KornerCarver
All cars have pressurized cooling systems. This one might make for a higher pressure but I doubt that would help for a street application. Higher pressure would certainly put additional stress on your radiator hoses.
Old Mar 15, 2010 | 08:41 AM
rcdash's Avatar
rcdash
Evans NPG+ essentially runs without pressure (few psi). No water, no hot spots, no air pockets from vapor formation, high boiling point...
Old Mar 15, 2010 | 08:54 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I run a pressureless system with an RX7 rad cap
Old Mar 15, 2010 | 09:47 AM
str8dum1's Avatar
str8dum1
^you car overheating is due to fan problems though right?
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
