Possible blown head gasket? Loud pop under boost log
Old Apr 29, 2010 | 06:12 AM
  #81
BrianLG35C's Avatar
BrianLG35C
Originally Posted by binder
the owner of the shop ended up emailing me about a week later asking how things were coming along and to let them know what i find out.
Yesterday i sent all the pictures and things to him letting them know the final outcome. We'll see what that brings.
Good, I hope things work out fairly for you. Very impressive DIY job!
Old Apr 29, 2010 | 07:00 AM
  #82
binder's Avatar
binder
Originally Posted by Vince@R/TTuning
Hey Jeff, Thats awesome!! Glad ya got it all back together and those gaskets worked out for ya. Hal will take good care of ya, im excited to see the results. Thanks for the good words!!! Let me know if ya need anything else.
Thanks, Vince
i do need more help. I posed this question to Hal also since he'll be the one messing with my car i wanted him to know what was going on.
"car is running great. During that last coolant bleed when i started the car at one point i got my abs, slip, and vdc light on. The car had the front end off the ground. I removed the steering knuckle to do my headers and when i put it back it was slightly off on the test drive but no codes. Then i unhooked it and moved it 1 spline clockwise and when i fired it up got the codes. I tried to reset them with cipher but it said no. It gives me 2 abs codes u1000 and c1104. I had a third but it's not there today. When i try to reset them it says "no response from device"
any suggestions?"
car drives fine, i'd just like my abs to be back on...lol
thanks!
Old Apr 30, 2010 | 09:38 AM
  #83
binder's Avatar
binder
Hal helped got me covered!
those abs codes were for front left wheel sensor. When i looked it up it just said abs. So i checked front left wheel sensor and it was unhooked!
When i pulled the supercharger to change the thermostat i must have pulled up on that wire right next to it causing it to unclip. Simply connecting it together and my problems are solved!
Old Apr 30, 2010 | 10:03 AM
  #84
str8dum1's Avatar
str8dum1
where did you see a list of ABS codes? can you link?
Old Apr 30, 2010 | 10:34 AM
  #85
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
FSM.
Old Apr 30, 2010 | 05:36 PM
  #86
binder's Avatar
binder
i googled them and it gave me some info but then Hal gave me the specific info "left front wheel sensor"
Old May 1, 2010 | 05:01 PM
  #87
str8dum1's Avatar
str8dum1
FWIW, heres a list of chassis and body codes as well
http://www.nagtroc.org/forums/index.php?showtopic=32433
i'm gettin c1107 which I think if front right wheel sensor, any one confirm?
Originally Posted by Hal@IP
FSM.
burglapfd
Dec 6, 2020 01:04 PM
sales@czp
Sep 23, 2019 03:30 PM
