Ditched my vortech: Built motor, greddy twins, budget build: updated 9-18-2010
#341
Ordered the RJM bracket. Read through the install which seems tedious and the setup and sounds like it could help me with my car.
If not......drop the transmission.
After doing the rear diff by myself i dont think i would do it again. Much less the transmission. That is a lot of weight hanging over your head.
#342
I believe 2003 uses the long pivot ball and newer vehicles like 2004-2006 350z and 2004-2007 G35 use the short pivot ball . I would get a chromoly short pivot bolt and not sure if you need a new clutch fork or not. I have installed the RJM pedal and it just takes some patience to tinker with the settings to get it just the way you like it.
www.rjmperformance.com
http://g35driver.com/forums/g35-coup...-run-away.html
#343
hatersgonnahate
![](https://my350z.com/forum/images/ranks/premier.gif)
Wondering if its worth checking the pivot ball.
We swapped the transmission and it probably came with the longer pivot ball.
Quamen and binder, you guys must be hulk!
#344
on
the pedal is easy to install. The turbo setup was much more complicated than that bracket. You'll be fine.
I wouldn't worry about the pivot. If anything the long pivot should give you more throw. I think it's just the nature of a heavy single disk clutch needing more throw on the clutch lever arm. You'll get that with the new pedal bracket.
#345
hatersgonnahate
Would like to see how some other peoples pivot fork/to slave cylinder look.
Pedal should be here soon.
TT install isnt that hard when you have the right tools, just time consuming. I bet I could pull the whole kit minus manifolds off in just a few hours now that I have done it once plus all the test fitting.
#346
on
what do you want to see on the pivot and fork?
the pedal will be a breeze for you. I took mine out to adjust it in about 15 minutes. I think i spent 45 minutes on the first install. RJM will answer any questions you have and I will also answer any if you need some tips when it comes.
#347
taking the trans out and putting it back in is pretty simple. ive done it twice now by myself. first time i tried using jacks then the second time i went under the car, pulled the tranny up on my chest and kinda bench pressed it up using my legs for stability. if you could get ahold of a tranny jack, i would do that.
#348
hatersgonnahate
Holy crap. Did not realize i hadnt updated this since may!
Installed the Rjm ajustable clutch bracket. Works great.
Retucked my haltech harness....i hate that thing.
Lots of work done, not all related but on the same car
https://my350z.com/forum/brakes-and-...n-details.html
https://my350z.com/forum/media-share...nder-area.html
https://my350z.com/forum/media-share...-progress.html
Working on cleaning up the engine bay some more and modding my headlights. The cup install took awhile and many other things.
Order a mizu radiator and fan shroud. had the passenger side coolant pipe redone, just need to install it with the new fan and rad. 4 more gallons of npg.
relocated a bunch of the tanks and re-doing my intercoler pipes/intake ect
![](http://i265.photobucket.com/albums/ii237/Cux350z/79701003-432E-4D86-8EC5-2D14D27A3EB3-19576-00001A5FEB7B07DE.jpg)
![](http://i265.photobucket.com/albums/ii237/Cux350z/C3767388-BFD4-494F-BF39-B20497F0E9BC-18896-00001A397BEF9810.jpg)
![](http://i265.photobucket.com/albums/ii237/Cux350z/DD1949E2-ED5B-486E-800B-999D1069FA1D-19576-00001A5FF8EB605F.jpg)
#351
hatersgonnahate
^yep. Same color as all my accessories. Green and red are complimentary. Hoping it turns out. From a distance and angles it will look black, with the right angle and light you will see the green.
#355
hatersgonnahate
She should be going into paint this weekend! Laundry list of things to do.
Trying to set up a tuning appointment but may have to wait since paint schedule could vary.
#359
hatersgonnahate
So a Big Update after nearly 5 years....She Made 640whp @18.5psi on 93pump at Z1 Last week.
![Name: Dyno_640.jpg
Size: 85.0 KB](https://my350z.com/forum/attachments/forced-induction/394592d1501408735-ditched-my-vortech-built-motor-greddy-twins-budget-build-updated-9-18-2010-dyno_640.jpg)
![Name: 20150118_165705.jpg
Size: 97.8 KB](https://my350z.com/forum/attachments/forced-induction/394593d1501408735-ditched-my-vortech-built-motor-greddy-twins-budget-build-updated-9-18-2010-20150118_165705.jpg)
Going to update the mod list since it changed since the first post:
SP engineering shortblock...8.8 arias with eagle H beam rods, HKS headgasket
Brian Crower Stg 2 Cams
Greddy TT kit, 18g, tial WG (Turbos are bored out to be td06h-20g in 18g housings) (custom piping from IC to TB with Vibrant Vanjen Clamp)
NWP larger TB kit
Haltech Platinum Pro Plug in ECU with dual widebands, integrated AEM boost gauge and boost control solenoid
AEM Oil Temp Gauge and Sensor wired to Haltech
MAF deleted
GM IAT
AAM competition 3" downpipes with open dumps
AAM oil pan spacer with return lines
OS Giken TR twin disk clutch. 215mm sprung disc
RJM Clutch Pedal
CJ motorsports stage 0 RFS , Custom Feed Line
CJM Twin Pump Hangar
CJM Dampened Fuel rails
Okada Projects Coil Packs
K&N replacement filters for the shrooms of death
Cosworth Intake Plenum
Rare JDM Engine Harness cover
Clampco Tbolt Clamps
Brian Crower Stage 2 cams
DW 800cc injectors
Earls performance Oil cooler with Mocal thermostatic sandwich plate
Coolant pipe modification for deletion of unneeded routing
Swapped in a lower mileage CD009 transmission
ARC Titanium Dual Exhaust
Volk GT-S Wheels
Stoptech BBK all 4 corners
BC BR coils
Exotic Air Cup Suspension
Authentic Bride Seats![Smilie](https://my350z.com/forum/images/smilies/smile.gif)
Zpec Fasteners for Engine Bay
Custom CIN motorsports Oil catch can
Custom CIN motorsports intake pipe for drivers side
Cusom CIN motorsports IC shrouding and Oil cooler air divert
NWP larger TB kit
MAF deleted
GM IAT
RJM Clutch Pedal
DW 800cc injectors
Volk GT-S Wheels
BC BR coils
