my SC Setup
Old Sep 1, 2010 | 12:54 AM
  #281
maXmood's Avatar
maXmood
Under Boost!
belt slipped about 1cm after couple of runs.. i don't think that's an issue.
the haltech reads upto 9.4psi (highest i've seen), so that's surely no slippage or leak.
other than the tune, what else can be adjusted/checked for full potential?
Old Oct 11, 2010 | 02:42 AM
  #282
maXmood's Avatar
maXmood
Under Boost!
Update:
Haven't had the time to fine-tune the car or even retighten the plenum or the belt.
i'm taking alot of time trying to understand tuning and especially on haltech, and it looks like it's gonna take me forever to learn. because trying to do trial and error is not viable since i don't have anyone to drive the car while i monitor/read the parameters.. plus being busy with work + uni.
i'm in the process of getting Tomei TPs + headers + straight pipes to replace H-pipe on my Borla exhaust, and "maybe" cams at a later stage.
once i get those installed, i'll have it re-tuned on the dyno.
Old Apr 25, 2011 | 09:06 PM
  #283
maXmood's Avatar
maXmood
Under Boost!
Update: (been long since last one)
Building the motor now, because there was lot of blow by, worn piston ring..
haven't driven the car since November 2010, all this time i was waiting for the vendor to send me the parts that he promised should reach me within couple of weeks which turned out to months of waiting time, and i had to cancel my order and deal with another vendor.
Anyways, parts arrived yesterday.. the build should start soon.
-Wiseco pistons - 8.8:1 cr, 96mm (0.020 overbore)
-Eagle rods
-ARP headstuds- L19
-ARP main bolts
-HKS headgaskets, 97mm
-ACL Tri-Metal Crankshaft Bearings
-ACL Tri-Metal Rod Bearings
-Clevite Thrust Washer set
-Pathfinder cooling mod (to cool rear cylinder heads)
-BC cams (Stage 2)
-Revup oil pump
I got those long time ago, which will go with the build:
-Snow Performance meth kit (stage 2)
-Tomei headers
-Tomei Test pipes
-TransGo Valvebody upgrade kit
Supercharger modifications:
-Upgraded blower including impeller
-Upgraded cog pulley
-GTM non-slip pulley
let's see where it takes me now..
Old Apr 25, 2011 | 09:15 PM
  #284
chrisjersey06's Avatar
chrisjersey06
Sounds like a nice build. Let us know what kind of power it makes. I'll be cheering from the sidelines with my big 'ol 3.33 still.
Old Apr 25, 2011 | 09:21 PM
  #285
maXmood's Avatar
maXmood
Under Boost!
thanks...
enjoy it in good health.
Old Apr 26, 2011 | 05:14 AM
  #286
rh_334's Avatar
rh_334
Out of curiosity what made you decide on low compression? (I think im remembering correctly that you were the one considering running ~10:1?)
Old Apr 26, 2011 | 10:41 PM
  #287
maXmood's Avatar
maXmood
Under Boost!
to avoid detonation with our crappy fuel.. + if i ever think of going TT
Old Apr 27, 2011 | 10:08 AM
  #288
JET MECH's Avatar
JET MECH
8.8 CR with a S/C is a very bad idea. Don't even bother wasting your money on the S/C upgrades and dyno time. Just sell the vortech and purchase the TT setup now. You will be very disapponted with the outcome.
Old Apr 27, 2011 | 12:19 PM
  #289
maXmood's Avatar
maXmood
Under Boost!
a friend is doing +450whp with almost the same setup.. and my goal is just 400whp.
TT is a future plan when im done with the SC
Old Apr 27, 2011 | 03:19 PM
  #290
350z-Na's Avatar
350z-Na
congrats Mahmood can't wait for the new setup
Old Apr 27, 2011 | 06:41 PM
  #291
chrisjersey06
That should be an easy goal. Mine makes that much with just the kit out of the box with the 3.33 and stock motor with a super conservative daily driver tune on 93 pump.
Old Apr 27, 2011 | 09:11 PM
  #292
maXmood's Avatar
maXmood
Under Boost!
^if you've gone through the whole thread, u'd notice that my motor isn't the norm.
Thanks
Old Apr 28, 2011 | 01:09 AM
  #293
Erdem's Avatar
Erdem
^^ the new motor will be, hopefully
Old Apr 28, 2011 | 02:07 AM
  #294
maXmood's Avatar
maXmood
Under Boost!
hopefully.. "fingers crossed"..
350Z_Al
Oct 29, 2020 07:44 PM
