my SC Setup
Old Jul 30, 2010 | 02:18 PM
  #201
binder's Avatar
binder
Originally Posted by Erdem
thanks for the input.. I just read about another member in here who had problems with the IPP block..
anyways for how long have u been driven the IPP STG1?
bad engines happen, that's why he has a warranty. You can get a bad engine build from any shop. Sometimes it just happens no matter how good the builder is.
Old Aug 1, 2010 | 11:04 PM
  #202
maXmood's Avatar
maXmood
Under Boost!
Ok.. here is an update for you guys.
Haltech and RFS got installed 2 days back, and yesterday i got the car tuned..
Being cautious and looking for reliability in this weather (110F), we got it upto 304whp on 7psi.
i'll do another tune in winter and try to adjust the timing to get a better outcome.
I'm not fully satisfied with the outcome, but i love the G power!..
Old Aug 2, 2010 | 02:54 AM
  #203
midz350's Avatar
midz350
Being cautious and looking for reliability in this weather (110F), we got it up to 304whp on 7psi.
Or do a tune now with water/meth or pure water injection
Old Aug 2, 2010 | 03:31 AM
  #204
maXmood's Avatar
maXmood
Under Boost!
^will have that added later..
Old Aug 4, 2010 | 01:40 AM
  #205
maXmood's Avatar
maXmood
Under Boost!
what's next to get a better output?
Old Aug 4, 2010 | 10:08 AM
  #206
binder's Avatar
binder
bigger intercooler to keep intake temps down. vortech intercooler is bad.
that or you can add meth.
and since you're only at 7psi you can go to a smaller pulley to up the boost.
304hp isn't bad. that's about a 40-50 hp gain for 7psi. Not bad at all for 110* temps outside.
Old Aug 4, 2010 | 11:48 AM
  #207
str8dum1's Avatar
str8dum1
its silly just adding parts without even knowing if you need them.
at the power, that IC is perfectly capable. Spearco rates it to 500whp.
your timing might be too conservative, your AFR might be too rich, your exhaust might be too restrictive.
Unless you have AIT logs showing 50-70*+ over ambient at WOT, i'd focus on other things.
Old Aug 4, 2010 | 12:10 PM
  #208
maXmood's Avatar
maXmood
Under Boost!
yea, thinking of the intercooler + meth.. our weather doesn't help at all.. in a year, we have 10 months of summer, and 2 months of spring. no winter or fall..
I'm already on 2.87" pulley..
my base dyno was 209whp on DJ, so that's about 95whp increase on 7psi.
Old Aug 4, 2010 | 12:14 PM
  #209
Erdem's Avatar
Erdem
how many BHP?
100 WHP gain is nice congrats bro
Old Aug 4, 2010 | 12:16 PM
  #210
Erdem's Avatar
Erdem
but that pulley should give you 10+ psi..
but I think you already knew that.
90% it is belt slip..
do u have boost graph?
Old Aug 4, 2010 | 12:24 PM
  #211
maXmood's Avatar
maXmood
Under Boost!
i agree on ur first statement, but i know that i need these parts, because we're suffering from excess heat.
again, true about the IC being perfectly capable, as it's rated to 400-500whp, but having a bigger mass, can lead to better cooling (could be the other way around, because it depends on the core design itself).
timing is too conservative, AFR is too rich and exhaust is restrictive.. all of this is true.
with meth, i can at least adjust the timing and get better results. and i'm planning to fix my exhaust (replace the HFC and fix the H-pipe).
my friend's Z produces more than 420whp @ 12psi in cool weather (that's 70F), but in the summer, he loses about 3psi! it goes to 9psi @ 6500rpm.
IMO, better safe than sorry.
Old Aug 4, 2010 | 12:28 PM
  #212
maXmood's Avatar
maXmood
Under Boost!
how many BHP?
Thanks bro...
no idea about the BHP.
true, the pulley should give me 10+, but as i stated in the post above "my friend's Z produces more than 420whp @ 12psi in cool weather (that's 70F), but in the summer, he loses about 3psi! it goes to 9psi @ 6500rpm."
so, that might be what's happening to my car now.
i don't think it's a belt slip, and i'll try to post the dyno sheet (i don't have a boost graph).
Old Aug 4, 2010 | 05:18 PM
  #213
GT-ER's Avatar
GT-ER
Where did you see that spearco rates the intercooler to 500whp? I honestly have never seen an intercooler rating for the vortech intercooler so don't think I'm challenging you on this, but Precision offers an intercooler somewhat larger than the Vortech one and they are both bar and plate with with the PTE having better density ( more cooling ) and PTE rates it for 600 crank hp on a turbo engine ( SC ratings are lower than TC ratings due to their drive losses ). This would translate to about 450whp on a supercharged car...and the PTE core is larger and better made.
FWIW, I switched out my Vortech intercooler to a cheap larger ebay core and gained 35whp at 367whp on a 5AT.
Old Aug 4, 2010 | 05:20 PM
  #214
GT-ER's Avatar
GT-ER
Thanks bro...
I dunno....hot weather will not help for sure...but my car, even when it does get to 100* outside, still puts out the same 12psi on my 2.87. I know hot weather will hurt you, but I doubt you'd even loose a whole 1 psi due to it.
Old Aug 4, 2010 | 06:10 PM
  #215
wenlipai's Avatar
wenlipai
I think is belt slip, I had the same psi but later found out it was belt slip!
Old Aug 4, 2010 | 09:07 PM
  #216
maXmood's Avatar
maXmood
Under Boost!
okay..
so, the question then is, what are the factors that would make u lose psi (boost)?
1-boost leak
2-belt slip
3-blower?
Old Aug 4, 2010 | 09:12 PM
  #217
maXmood's Avatar
maXmood
Under Boost!
at first i saw a belt slip, and the car was producing about 5-6psi max.. i replaced the belt with a shorter one, and now i see 7psi
should i try to tighten the belt? get another tune after that?
Old Aug 5, 2010 | 04:39 AM
  #218
GT-ER's Avatar
GT-ER
I would try to tighten the belt more. My belt is VERY tight...it feels like a guitar string..lol.
Old Aug 5, 2010 | 06:08 AM
  #219
Chef-J's Avatar
Chef-J
Booooosstt!!
Again. Too tighted belt can break down the road. Which that happend to me on highway.
When I had my car in TX, it usually hit over 100 degree here in summer. I saw over 10psi easy with 2.87 pulley and same IC that everyone has. No prob.
Old Aug 5, 2010 | 06:27 AM
  #220
Chef-J's Avatar
Chef-J
Booooosstt!!
Btw, I read thru other forum other day. Here is one guy said how he check belt slip.
Mark line on belt/pulley and go full run and see if that mark isn't line up after pull. If its not line up, u know its belt slip.
Sounds like it will work. Haha
