my SC Setup
Old Aug 17, 2010 | 05:01 PM
  #241
GT-ER's Avatar
GT-ER
Originally Posted by binder
GTER, you also aren't taking into consideration your IAT's when you ran 20*. If he's seeing 150-160* intake temps (which is VERY possible with a 120* ambient outside temp) then he can't run near as much timing. Just going from 100* intake temp to 140* intake temp hal had to pull 3* of timing on mine to keep it from detonating. Intake temps make a big impact on the amount of timing that causes detonation.
I regularly see over 160* of intake air temp if I do one or two pulls. Heck, single 1st, 2nd, 3rd gear run will get me to over 150*...in my very first pull. At these IAT I run the timing I mentioned before. Granted, I don't know what Maxmoods IAT's are. If he's seeing over 200* then I would agree he would have to be very conservative. But if he's seeing the same numbers I am...his timing seems fine to me.
I'm so anxious for my WMI to get here...lol.
Old Aug 17, 2010 | 07:42 PM
  #242
binder's Avatar
binder
ya, my thinking was the fact that we see up to 140's and 150's with an ambient temps in the 90's. He has ambient temps 30* higher than ours so i would expect his IAT's to be about 30* higher than ours. That's a pretty high IAT.
Old Aug 17, 2010 | 07:56 PM
  #243
GT-ER's Avatar
GT-ER
True...Maxmood...how are you IAT's?
Old Aug 17, 2010 | 11:16 PM
  #244
maXmood's Avatar
maXmood
Under Boost!
Thanks for the input guys.. you keeping me busy reading
i'm using AEM EUGO gauge.. and i'm not sure if my haltech is calibrated or not. who should calibrate it? mechanic, tuner? can i do it by myself? how?
i did mention my AIT couple of times before, but here goes:
IAT = 42c (108F) to a maximum of 54c (129F)
Coolant temp = between 90c (194F) to a maximum of 92c (198F)
i got koyo rad + tranny/engine oil coolers
Old Aug 18, 2010 | 08:44 AM
  #245
midz350's Avatar
midz350
Set it like this:
Volts 0.00 5.00
AFR 10.0 20.0
Old Aug 18, 2010 | 12:19 PM
  #246
maXmood's Avatar
maXmood
Under Boost!
Originally Posted by midz350
Set it like this:
Volts 0.00 5.00
AFR 10.0 20.0
please elaborate..
btw guys, i just found out a leak in the plenum (i have MD plenum spacer). i wiped the area clean and i'll give it a day or two to trace out the leak source.
plus, i've marked the belt+pulley to see if the belt is slipping.
Old Aug 18, 2010 | 01:20 PM
  #247
Erdem's Avatar
Erdem
I remember another member suggesting this, but couldn't figure if he was being sarcastic or not.. but honestly, I don't think it will help you at all..
1. the 3.12 pulley will spin, I think about 5 hole rounds before the mark on the belt is back to starting point.
2. I think it is "normal" for the belt to slip milimeters @ WOT, and you wouldn't be able to tell if it was "belt slip" or not..
not sure though?
EDIT: Still worth giving it a try..
Old Aug 18, 2010 | 01:30 PM
  #248
maXmood's Avatar
maXmood
Under Boost!
not sure though?
come to think about it, you're correct.. i won't be able to match the mark unless it spins couple of times. but if it doesn't match up at all, then there must be a slip.
Old Aug 18, 2010 | 01:36 PM
  #249
Erdem's Avatar
Erdem
as I said worth giving it a try..
how do you like the 100hp increase.. I wish it was me.
Old Aug 18, 2010 | 01:55 PM
  #250
maXmood's Avatar
maXmood
Under Boost!
100whp is fun, but not the whole fun.. i wish it reached my expectation (+360whp). dunno what's wrong.
Old Aug 18, 2010 | 06:27 PM
  #251
binder's Avatar
binder
so it's 120* outside and you are only getting 128* intake temps? how is that possible?
We need intake temps when you go WOT a few times in a row, not when you are at cruise.
about your haltech, you need to look in the aem manual and see what the aux output wire of the aem is and set those settings in the main menu of haltech (f4 button). I do'nt think the aem is 10-20 af. I think it's slightly different so check it and put those values in the haltech.
about the belt slip, it will be hard to tell, you won't know exactly how much it's slipping. It will always slip some. There is no way to have a serpentine belt system and not have any slip. It's designed TO slip for protection of the parts. So ya, you'll have movement of the line, the problem is, did that line move a little, or did it move so much that it made it all the way back around.
By the look of your boost log, it doesn't appear to be belt slip. You're building boost all the way to redline. If you had slip you'll see the boost line level off. It should always build boost if rpms go up.
So plenum leak would cause low psi and would still allow it to continuously build boost. Fix that boost leak.
Old Aug 18, 2010 | 06:42 PM
  #252
GT-ER's Avatar
GT-ER
eye agri
Old Aug 18, 2010 | 06:59 PM
  #253
binder's Avatar
binder
http://www.schnitzracing.com/manuals/AEMWBK.pdf
mahmood
open your map in haltech, click the f4 button to open the main menu then under wideband you enter the numbers they have in that chart for volts and a/f gasoline.
It appears these are some numbers you can plot:
0v=10.0 af
0.62v=11.24 a/f
2.34v=14.68 a/f
4.99v= 19.98 a/f
That should be enough to get it calibrated. If not you can put more points on to make sure it's linear.
Then your haltch should show what your uego shows and you can log it properly.
Old Aug 18, 2010 | 10:06 PM
  #254
maXmood's Avatar
maXmood
Under Boost!
the AIT log is after 2 runs (logged with cipher).. i'll try to do couple of runs and get that logged.
boost is building up and it looks fine on haltech (9.3psi), but i'm not seeing the same on the boost gauge (7psi). so i'm not sure if there is a belt slip or not.
i just ordered a torque wrench especially for the plenum
Old Aug 18, 2010 | 10:09 PM
  #255
maXmood's Avatar
maXmood
Under Boost!
mahmood
0v=10.0 af
0.62v=11.24 a/f
2.34v=14.68 a/f
4.99v= 19.98 a/f
thanks a bunch bro, i'm gonna do that and let you know how it goes.
Old Aug 19, 2010 | 01:38 PM
  #256
binder's Avatar
binder
never trust a gauge. Gauges can be wildly off. Go by what your haltech says.
My gauge reads higher than my haltech. The needle is probably off or something wacky. Who knows. Gauges are only a reference, not a tuning tool. You tune on your logged stuff that the ecu is using to calibrate your fuel.
Old Aug 20, 2010 | 03:49 PM
  #257
maXmood's Avatar
maXmood
Under Boost!
binder, i entered the numbers/volts, in both widebands, saved it, rebooted the ecu, but i still can't see it logging the AF?
any idea which channels i should be logging?
i tried:
Calibrations - O2 wideband sensor 1 and 2
Fuel - Targert AFR
Special - Actual O2 value bank 1 and 2
Old Aug 20, 2010 | 04:17 PM
  #258
Threads's Avatar
i tried:
Fuel - Targert AFR
Excuse my ignorance on your setup, but do you have your AEM UEGO serial output wire wired to one of the AUX inputs on the Haltech harness?
I am going to be installing my Haltech tomorrow. However, I will be using Haltech dual wide-bands. If you don't solve the problem tonight, I would be more than happy to help further with your "problem" tomorrow once mine is installed.
Old Aug 20, 2010 | 04:34 PM
  #259
maXmood's Avatar
maXmood
Under Boost!
i'm not sure if this wa wired or not, because i'm not the one who installed the haltech..
let me know how it goes with you, i might try to follow your instructions if they're DIY.
thanks
Old Aug 20, 2010 | 08:58 PM
  #260
binder's Avatar
binder
ya, you have to have the aux output wire hooked to the wideband 1 input on the haltech harness.
I'm pretty sure the serial output is different than the aux output. Yep, just checked it, you want to use the aux output (WHITE WIRE) to the haltech input on wideband 1. Then go into the haltech menu and put those calibrations into the O2 1 sensor.
You will datalog Calibrated o2 sensor 1.
