** My build w/ boosted performance ST kit!! - lots of pix! **
Old May 24, 2010 | 08:37 PM
  #181
tiguy99's Avatar
tiguy99
Originally Posted by Elperuano
So....results?
He's still driving it
I would have gone through 2 full tanks of gas by now hehe
Old May 25, 2010 | 05:09 AM
  #182
Vas_Z33's Avatar
Vas_Z33
whats up fellas!!.... sorry I got home really late last night
well bottom line.. the tune isnt finished yet... I have to go back. I have the car back and everything but it is tuned for only 4 psi. The tune was also double conservative. It made 309/ 303 tq. again this is only at 4 psi and extremely conservative.
We were having some problems keeping the boost full steady at 8 psi. But full force is being taken care of. We are going to run it with an open dump and I have an EBC coming in overnight ( thanks Sasha your the man ). So I will report back very soon.
Vince@R/T Tuning , did all of the tuning.. and the car even at its state feels unreal!!.. Its really , really hard to believe that im only putting out those numbers!!^.. once it hits 4K it puts you back into the seat pretty damn hard and the noise that comes out of this thing really scares people away. I can only imagine at 8 pounds . Vince's tune is unbelievably good! the car drives like NA.
you guys can feel free to chime in with comments and give me some opinions, I dont mind... but sh*t happens.. and I am ok with that.. I know that it will get fixed, because I wont sleep until I do!.
Old May 25, 2010 | 05:26 AM
  #183
IslandZavage's Avatar
IslandZavage
when are you going back too finish the tune?
Old May 25, 2010 | 05:31 AM
  #184
Vas_Z33's Avatar
Vas_Z33
I have to call vince and find out... I cant do anything till fri cause I have work.. I know they are busy because of track day this weekend.. but Im sure vince would work something out
Old May 25, 2010 | 05:47 AM
  #185
CRIDDA's Avatar
CRIDDA
even with the sts kit, I think I remember seeing that they had the same problem(not able to hold steady boost and boost not coming full in 1st or 2nd) EBC solved that problem. I hope that is the only problem. Did you have any leaks?
Old May 25, 2010 | 06:34 AM
  #186
Vas_Z33's Avatar
Vas_Z33
yeah Vince recommended the ebc. We shall see. No leaks. Vince did a smoke test and it past with flying colors
Old May 25, 2010 | 07:05 AM
  #187
Blck350z's Avatar
Blck350z
your getting this done at R/T!!! I might have to pop down.... its only 1.5 hrs away from me.... let me know if you don't mind another z guy watching this dyno?!?!
Old May 25, 2010 | 07:11 AM
  #188
Vas_Z33's Avatar
Vas_Z33
More than welcome to man... Please do!
Old May 25, 2010 | 07:13 AM
  #189
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
You will have the new EBC tomorrow AM.
Overnight FTW..
Old May 25, 2010 | 07:21 AM
  #190
Vas_Z33's Avatar
Vas_Z33
Sweet!^
Old May 25, 2010 | 07:26 AM
  #191
CRIDDA's Avatar
CRIDDA
Sasha- did you use an EBC on your set-up(too lazy to go back and reread)? It might be something that you want to offer in the kit.
Chris
Old May 25, 2010 | 08:07 AM
  #192
Vas_Z33's Avatar
Vas_Z33
I think he is running one ^
Old May 25, 2010 | 08:19 AM
  #193
Boosted Performance
Chris
I am using the EBC via Haltech right now.
If you guys recall this dyno (with boost logged):
You can see how the boost drops. At first I thougth it was the turbo, or the way the wastegate recirculation tube was plumbed (90deg entry at down pipe) ect. That dyno was on wastegate spring recirculated w/g and OEM style rear muffler
This is the thread; https://my350z.com/forum/forced-indu...-resulsts.html
It turned out to be my rear muffler. Once I had it removed and replaced it with just a 2' piece of straight pipe the boost on spring pressure was as follows (from Hltech log):
RPM/ Boost
3.5k/ 5.5psi
4.0k/ 8.9psi
4.5k/ 8.9psi
5.0k/ 8.3psi
5.5k/ 8.4psi
6.0k/ 8.3psi
6.5k/ 8.0psi
When I put the rear muffler back on, it got all screwy again, with boost tapering off after 4500rpm.
So my conclusion was that the muffler was a restriction. After that, there was only on logical thing to do...cut the f...er open:
http://i137.photobucket.com/albums/q...D/S1031833.jpg
As you can see, that thing was a huge restriction. I removed some stuff from it, but it still didn't do what I wanted it to. After that I put the EBC on and dialed in 8psi through the entire RPM range. Made 402whp with 8psi of boost after that, with the OEM style muffler linked above. The exhasut is queter than stock.
Old May 25, 2010 | 08:20 AM
  #194
MI 35th's Avatar
MI 35th
OGPremierMafia
VAS. pics & vids....
Old May 25, 2010 | 08:22 AM
  #195
CRIDDA's Avatar
CRIDDA
I think he is as well, but wasn't 100% sure
Old May 25, 2010 | 08:24 AM
  #196
CRIDDA's Avatar
CRIDDA
RPM/ Boost
3.5k/ 5.5psi
4.0k/ 8.9psi
4.5k/ 8.9psi
5.0k/ 8.3psi
5.5k/ 8.4psi
6.0k/ 8.3psi
6.5k/ 8.0psi
Thanks Sasha. I thought this is what you ended up doing, but wasn't sure.
Looks as if the EBC is almost a must
Old May 25, 2010 | 08:25 AM
  #197
Boosted Performance
BTW this is the EBC I will be offering with the kits:
http://www.aemelectronics.com/tru-bo...ller-gauge-757
Old May 25, 2010 | 08:31 AM
  #198
CRIDDA's Avatar
CRIDDA
Sasha, I must say that you are on top of your game. When the time is right(just bought a house so moniez are tight) I know who I will be in contact with. Your service and attention to detail is what has kept me at bay since day one. Also your willingness to listen to what people have to say about ways to improve your kit, and then off you go to make something happen. One must not forget your robotic welds(don't lie we know you built yourself a robot to do that for you). I just want to thank you for your service to the community and wish the 1st few users of your product nothing but the best(as this is what you intended when you built this unit).
Chris
Old May 25, 2010 | 08:46 AM
  #199
Vas_Z33's Avatar
Vas_Z33
yeah hopefully that will solve my issue of boost dropping to 4... I know my exhaust isnt restrictive though.. so we will have to see what the EBC does.
Old May 25, 2010 | 08:48 AM
  #200
Vas_Z33's Avatar
Vas_Z33
I will see what I can do.. Ill post some pix of when I was installing it and a few camera pix from my phone at the R/T... all depends when I get out of work.. I got some work to do at home too so... if anything, ill take vids tomorrow
