** My build w/ boosted performance ST kit!! - lots of pix! **
Old May 25, 2010 | 01:20 PM
  #221
rcdash's Avatar
rcdash
Originally Posted by binder
it says 0.4psi, not 4 psi
dang it, i wish i had dual mode boost controller. That would solve my delima with having 2 boost pressures to select. I'm not really in the mood to spend 300$ on top of my haltech already though.
Are you using the internal or external MAP sensor? If not using the external MAP sensor, I think you could get that input to work as an input for boost selection (*I think* - this is unsupported so you might need Hal's help).
With a carPC, it's easy to modify on the fly!
Old May 25, 2010 | 01:28 PM
  #222
binder's Avatar
binder
i use car pc but you have to reboot the haltech (turn car off and back on) if you want to change anything.
do you change maps or just adjust in the settings? either way i think you have to reboot which is a pain and not really "on the fly" since the key has to shut the car off.
i'm using internal. I was going to tune to wastegate (14ps) then have my boost controller hold at 25psi for my big boy all on the same map. If i can find a way to disable the solenoid then the flick of a switch would switch me from w/g 14psi to b/c at 25psi.
RC, pm me. i don't want to clutter up the thread. I need some info on how i can setup what i want on this haltech. Hal is tuning it for me but i need to know what all to buy to set it up properly.
rich: quit going off the radar and answer that last pm! lol
Old May 25, 2010 | 01:29 PM
  #223
tiguy99's Avatar
tiguy99
I like the idea of using the car PC. It seems like u can use them to monitor just about anything
Old May 25, 2010 | 03:10 PM
  #224
athenG's Avatar
athenG
I know what he meant. I was referring to to the OP's pressure lost of 4psi. a 0.4psi lost is awesome if it is accurate because even FMIC maker brag about their IC if it is less than 1psi drop. So he's only loosing .4psi with that IC and piping
Old May 25, 2010 | 03:11 PM
  #225
Vas_Z33's Avatar
Vas_Z33
there should definitely not be a 4psi drop at redline... Like sasha said, about .5 is about right.
Im going to do the waste gate tomorrow.. and check the spring... and no jeff, I cant quit work loll
Old May 25, 2010 | 03:56 PM
  #226
binder's Avatar
binder
ah, ic!
Old May 25, 2010 | 04:26 PM
  #227
str8dum1's Avatar
str8dum1
His spring is 8psi but he's dropping to 4psi. 4 psi loss....
I think he said 0.4 psi, not 4 psi lost. Wastegates should not see vacuum so the compressor housing is a good choice. Stronger pressure there creates the greater differential against atm for wastegate control.
Solid BP!
Originally Posted by Boosted Performance
Vas did not buy it. I thought it was up to me to get what he payed for. I bought the EBC with my own money, and shipped it to him over nigh.
Old May 25, 2010 | 05:23 PM
  #228
zmedic16's Avatar
zmedic16
boosted performance FTW. that was very neat ^
Old May 25, 2010 | 05:24 PM
  #229
Vas_Z33's Avatar
Vas_Z33
yes it was.. His customer service always amazes me
Old May 25, 2010 | 06:32 PM
  #230
Elperuano's Avatar
Elperuano
My man
Now THAT'S customer service!
Old May 25, 2010 | 07:00 PM
  #231
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
Thanks guys. I have always said that it's not just the product that is important, but also what comes after the product has been sold.
Old May 25, 2010 | 10:04 PM
  #232
ppwpz33's Avatar
ppwpz33
Hey this may have been covered already but what front bumper is that? It sorta resembles the Nismo V3 but I don't think that's it or is it? I like the cf at the bottom.. should look great! Thanks in advance.
Old May 26, 2010 | 03:17 AM
  #233
Vas_Z33's Avatar
Vas_Z33
pmed
Old May 26, 2010 | 05:37 AM
  #234
aln's Avatar
aln
get going fixing the issue now and post some vids up
Sasha's customer service is brilliant... can't believe reading that actually... is this real?
Old May 26, 2010 | 05:43 AM
  #235
Vas_Z33's Avatar
Vas_Z33
I will just gotta fix some stuff and check things over..
it is real!... he has been there every step of the way throughout this whole thing
Old May 26, 2010 | 05:46 AM
  #236
aln's Avatar
aln
I want I want!
Old May 26, 2010 | 06:19 AM
  #237
Vas_Z33's Avatar
Vas_Z33
I was just told the EBC came!!
Old May 26, 2010 | 06:22 AM
  #238
CRIDDA's Avatar
CRIDDA
So I guess you need to let the boss know you don't feel so good, a case of the runs Hope this gets you where you need to be
Old May 26, 2010 | 06:37 AM
  #239
Vas_Z33's Avatar
Vas_Z33
lolol.. I wish man... It sucks I cant leave, its a job that I need to be here .... does sound tempting though
Old May 26, 2010 | 06:45 AM
  #240
thom000001's Avatar
thom000001
Liking the power delivery of a turbo vs the vortec???
Kinda nice to have some tq huh?
Tom
