** My build w/ boosted performance ST kit!! - lots of pix! **
Old May 25, 2010 | 09:00 AM
  #201
MI 35th's Avatar
MI 35th
OGPremierMafia
VAS are you going to build your motor eventually?
Old May 25, 2010 | 09:01 AM
  #202
Vas_Z33's Avatar
Vas_Z33
yes
Old May 25, 2010 | 10:25 AM
  #203
str8dum1's Avatar
str8dum1
So the wastegate only has a 4psi spring?
That AEM is a nice piece and being 52mm is nice and versatile
Old May 25, 2010 | 10:34 AM
  #204
thom000001's Avatar
thom000001
I have that bc too....simple, easy to use, gets the job done (held 30psi for me )
Tom
Old May 25, 2010 | 10:45 AM
  #205
Vas_Z33's Avatar
Vas_Z33
the correct spring in there is the 8psi... Ive been talking to sasha and IP said they changed the spring them selves and it says so on the Tial box as well
Old May 25, 2010 | 10:48 AM
  #206
Vas_Z33's Avatar
Vas_Z33
Tom
awesome!, good to know someone is using it at such high psi.... btw does this bc act as a boost gauge as well? ... i mean does it eliminate the need for a boost gauge.. I have a prosport in there... if so I wanna take it out if the AEM can kill 2 birds with one stone
Old May 25, 2010 | 10:54 AM
  #207
str8dum1's Avatar
str8dum1
ya boost gauge and controller.
I still thats really weird that your 8psi spring only hold 4psi....... There's gotta be something else going on...
Old May 25, 2010 | 11:13 AM
  #208
Vas_Z33's Avatar
Vas_Z33
I'm looking at the box.. It says .5 bar but the. There's another .6 number... Kinda confusing... It's weird because we neverrr saw 8 psi . Max was 6.88 ... Which is a about .5 bar... That's what Vince is wondering too... I'm going to remove the w/g and look at the spring color...to confirm.. You never know I guess
Old May 25, 2010 | 11:39 AM
  #209
athenG's Avatar
athenG
Where is the WG reference? Plenum or Turbo?
Old May 25, 2010 | 11:42 AM
  #210
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
Turbo compressor housing.
  #211
Vas_Z33's Avatar
Vas_Z33
From turbo
Old May 25, 2010 | 11:50 AM
  #212
athenG's Avatar
athenG
From turbo
Where is your boost gauge reference? If it's on the plenum then it's about right because you have to account the pressure lost from the pipings and the FMIC.
Old May 25, 2010 | 12:03 PM
  #213
Boosted Performance
Mmm no.
I have a .4psi difference between the turbo pressure and manifold pressure. The piping is large diameter and the FMIC is a good flowing vertical (spearco) core.
The EBC will take care of this, I am sure of it.
Old May 25, 2010 | 12:09 PM
  #214
athenG's Avatar
athenG
Originally Posted by Boosted Performance
Mmm no.
Yes the EBC will solve this. 4psi lost for a mid-mount is a little high. STS has about 3-4psi lost but the STS is further down but our piping is smaller though and the FMIC is also smaller. Did the OP check for any boost leak?
Old May 25, 2010 | 12:10 PM
  #215
str8dum1's Avatar
str8dum1
ya, but you really should not have to spend 300$ more on a BC to run spring pressure on a stock block. Have you tried a 40$ MBC to see if that fixes it. Much more economical option for those that will only ever be running 1 boost level
Old May 25, 2010 | 12:14 PM
  #216
athenG's Avatar
athenG
EBC also help you spool better.
Old May 25, 2010 | 01:07 PM
  #217
ashtrojan2008's Avatar
ashtrojan2008
i would move to w/g reference to the cold side, somewhere before the tb. boost at the engine is what matters, who cares what's at the turbo. if i have an 8psi spring i want 8psi on w/g.. that's just my opinion
and i'm seriously considering installing this kit on a couple of my friend's cars. Can't wait for final results
ross
Old May 25, 2010 | 01:15 PM
  #218
rcdash's Avatar
rcdash
I think he said 0.4 psi, not 4 psi lost. Wastegates should not see vacuum so the compressor housing is a good choice. Stronger pressure there creates the greater differential against atm for wastegate control.
Old May 25, 2010 | 01:16 PM
  #219
Boosted Performance
Vas did not buy it. I thought it was up to me to get what he payed for. I bought the EBC with my own money, and shipped it to him over nigh.
Old May 25, 2010 | 01:17 PM
  #220
binder's Avatar
binder
it says 0.4psi, not 4 psi
dang it, i wish i had dual mode boost controller. That would solve my delima with having 2 boost pressures to select. I'm not really in the mood to spend 300$ on top of my haltech already though.
