** My build w/ boosted performance ST kit!! - lots of pix! **
Old May 27, 2010 | 03:24 AM
  #281
Vas_Z33's Avatar
Vas_Z33
Originally Posted by ForcefedZ
Is the check engine light on? If it is, and depending on the code the factory computer could be disabling the VCT.
no check engine light... Vince went over them and cleared them... VCT?
Old May 27, 2010 | 03:41 AM
  #282
ForcefedZ's Avatar
ForcefedZ
variable cam timing
Old May 27, 2010 | 03:56 AM
  #283
Vas_Z33's Avatar
Vas_Z33
variable cam timing
ah ok, I dont think so...I will ask my tuner though..
Old May 27, 2010 | 06:19 AM
  #284
zmedic16's Avatar
zmedic16
if vct is off it can affect where you are hitting boost.
Old May 27, 2010 | 06:37 AM
  #285
Vas_Z33's Avatar
Vas_Z33
I pmed Vince... Anyway to check that?
Old May 27, 2010 | 06:51 AM
  #286
binder's Avatar
binder
Originally Posted by Elperuano
Ohhh maybe mine's tuned differently or sumthin.... Dependin on how I start off from the roll I can feel it full boost before 4k n the "kick" from the tq kicks in right before then...
I hit full boost at like 3.4kish or so..
well I'll try to explain this simple. I'm not sure ur boost but on higher boost when boost firsr comes on ull have a hit of tq at that point. That's normal with turbo spool.
in vas's situation it is different. At only 4 psi the torque will come on more like an n/a car which means the highest point of tq will be at the standard peak near 5k. It isn't a large amount of boost to cause a significant "kick" down low. Bascially he's going from 0 to 4 psi verses prob 0-8 psi on a normal setup. Thats's double the boost down low therefor a huge kick in tq down low.
Old May 27, 2010 | 07:07 AM
  #287
ForcefedZ's Avatar
ForcefedZ
If you do not have a check engine light it's working. I would double check that the wastegate valve seat was installed.
Old May 27, 2010 | 07:35 AM
  #288
Elperuano's Avatar
Elperuano
my SES light is on... but i could expect that wit FI and a Haltech ecu....
Ohhhhh, gotcha!
Old May 27, 2010 | 09:33 AM
  #289
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
Very good point. Vas I assume it is installed. Picture of what it is and where it goes:
I hope to have my car back on the ground in about 3 hours, and then I can go for a rip.
I will post back with my results, and where the boost comes on with the larger T4 turbine, vs the old T3. I had to redo a bunch of stuff on my old set up, so it is identical to the setup Vas has on his car. New DP with recirculated w/g and a few other things.
Old May 27, 2010 | 10:02 AM
  #290
Vas_Z33's Avatar
Vas_Z33
I got that one in! Don't worry!
Old May 27, 2010 | 10:30 AM
  #291
binder's Avatar
binder
why would you expect that? i didn't have a code with osiris and still don't have any codes with my haltech.
You should never "expect" just because you are FI that you are supposed to have codes.
Old May 27, 2010 | 10:47 AM
  #292
Vas_Z33's Avatar
Vas_Z33
+1^
Old May 27, 2010 | 03:39 PM
  #293
Boosted Performance
Default Results
Well, like I said earlier, I stayed at home to modify my kit to fit the same turbo that Vas has. It took me all day, but I finally got it done and have some results.
I have to say that the T4 6262 .58 a/r is an awesome turbo, I will leave it on the car and prefer it over the T3 6162 .81a/r that was in there before.
When it spools up, it sounds incredible and pulls harder (at least if feels like so) than the old T3 6162
Here are a few shots of my data log with this turbo. This is a 3rd gear pull, spring pressure only in the w/g and a .6 (8.82psi) bar spring. There are no other mods done to the car, and this is with the Ebay 3" Megan racing knock off exhaust (restrictive muffler). Wastegate is recirculated, and you can see neart the top of the RPM range the boost/rpm is a bit spiky. This is do to bumpy roads, so traction was not 100% at that time.
Here is 3.5psi @ 2964rpm:
6.3psi @ 3305rpm
9.2psi @ 3632rpm
8.4psi @ 6161rpm
Clearly this turbo is well matched for the VQ.
On that note. Vas, since you don't have any boost leaks (tested) I would suspect that you have some massive exhaust leaks. Use your man muscles and tighten up the header bolts, and the T4 flange bolts. These results tell me that the turbo/setup is just fine.
If you can't get to the T4 bolts and tighten them with the turbo in there, you may want to turbine from the turbo.
EDIT:
Also, make sure that the V-band flanges on the crossover are "true". When they come together they should lign up perfectly. If they don't, loosen up the header bolts, and line them up. When they are flush put the V-band clamp on and tighten it well. At this point go back and tighten the header bolts. Don't do it in revers.
The only other thing I can do is book a flight, come over B-slap you and do the install....
Old May 27, 2010 | 04:28 PM
  #294
Vas_Z33's Avatar
Vas_Z33
Awesomeeeeeeeeee,,, it's gotta be something that I have no response... I can't hear here my bov even at 4k... Yet u see 9! At 3.5!!!!!!
I
know where I'll be tomorrow ... U got pm
a little dissapointed that I wasn't able to getthis right the first try at the dyno ... Oh well can't wait till next tune!
Old May 27, 2010 | 04:49 PM
  #295
boostedmaxima's Avatar
boostedmaxima
Props to Boosted Performance with the customer service and all. This thread is inspiring. I love when people get creative espeically when it comes to boost. Looking forward to more pics and vids of this setup.
  #296
zmedic16's Avatar
zmedic16
i guess that clears it.
Old May 27, 2010 | 04:59 PM
  #297
Boosted Performance
I should note that there will not be a T3 turbo option. I will switch to a true T4 flange, over the T3/T4 flanges.
This will make things simpler for me, and give the end user a variety of turbo option with the 67mm being the top dog.
This issue Vas is having was driving me nuts. I had to spend the day duplicating his set up just to be 100% sure that there is nothing wrong with the kit. Clearly everything works as it should. Now we just have to get Vas on the right track...
Old May 27, 2010 | 05:16 PM
  #298
athenG's Avatar
athenG
/\ I wish you routed the charge pipe on the right side (passenger side) so it will be easier for me to switch. Well that is if you are willing to sell me a tuner kit.. more like a tuner/tuner kit because I just really need everything before the IC...lol
Old May 27, 2010 | 05:35 PM
  #299
Vas_Z33's Avatar
Vas_Z33
bp ftmfwwwwwwww
Old May 27, 2010 | 05:54 PM
  #300
zmedic16's Avatar
zmedic16
6765 .81ar here we come!!! lol
