Brian Crower stroker kit? and big cams??
Old May 27, 2010 | 07:33 AM
thom000001's Avatar
thom000001
That or smaller cams (more mid less top).
I wish with the location of our turbos we could get QSV's in there....that'd be t!ts...
Tom
Originally Posted by str8dum1
he was referring to run smaller turbine housing which would possibly limit top end power with increased exhaust back pressure
Old May 27, 2010 | 07:59 AM
djtimodj's Avatar
djtimodj
Tom
Why not cut an inch out of the header collector and then use the QSV as a spacer to get the turbo's back to there original postion?
Seams less work and cost than, a stroker/ cams / NO2 etc?
Old May 27, 2010 | 08:19 AM
ttg35fort's Avatar
ttg35fort
Professional
If this is possible, it seems to me to be the best option. Based on the dyno plot presented by Sound Performance Racing in another thread, it looks like it will have a bigger impact than going with a stroker motor at a fraction of the cost. Here is the link: https://my350z.com/forum/forced-indu...e-on-gt42.html. The QSV improved spoolup by something like 700-800 rpm. I don't think going from a 3.5L to a with a 3.8L stoker motor will buy you as much.
Also, when you go with a stroker motor, you have greater stress on the engine internals. At a given rpm, the pistons are traveling farther in the same amount of time, and thus will have greater speed and momentum. I went with the billit main caps to add strength, but that is another added expense.
EDIT, here is a dyno plot for a different car from Sound Performance's website. In this instance, the spoolup looks to have improved by about 300 rpm or so.
Old May 27, 2010 | 08:20 AM
thom000001's Avatar
thom000001
Its not the spacer itself that is the issue, there is a actuator that takes up a fair amount of space (think of a wastegate actuator and rod on a internally gated turbo...same thing).
And there just isn't much room for that piece in there.
Tom
Old May 27, 2010 | 09:00 AM
str8dum1's Avatar
str8dum1
plus you have to add in the cost of going to a custom dual scroll turbine housing x2 plus the ceramic coat... Its not cheap to retro fit. You have to build with the QSV in mind from the start.
Old May 27, 2010 | 09:42 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Originally Posted by Z1 Performance
. Any machinist worth anything can easily work with it
+1
Old May 27, 2010 | 10:39 AM
go-fast's Avatar
go-fast
Originally Posted by rcdash
Interesting analysis. The horsepower loss aside, the squirters do serve a purpose, especially say in endurance type of racing? The GTM stroker kit is designed to rev to 8k and retains the oil squirters. Do you have experience with the GTM stroker? Can you compare both of these kits?
the availability of thermal coatings renders squirters obsolete.if you want a huge power suck keep'em.
and yes but no comment on gtm,i'm worn out beating that drum
