I'm the proud Father of...
Old Jun 21, 2010 | 06:22 PM
seymore4's Avatar
seymore4
Professional
built VQ35DE rev-up
GTM stage 2 kit with a return fuel system (GTM stage 5 with the CJM twin pumps)
Old Jun 21, 2010 | 07:57 PM
jeffie7's Avatar
jeffie7
I've got a utec for sale
Old Jun 22, 2010 | 07:11 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
On an HR, I would suggest an Uprev ECU flash over the emanage Ultimate. Looks like a fun build. You will really like what the Greddy TT Tuner kit does on the later generation engines.
Old Jun 22, 2010 | 07:25 AM
SV1098's Avatar
SV1098
Sounds good to me.
I plan on using Greddy's Management for 3-5 months. After that, I'm going with something different.
Any ideas on the numbers i should achieve? Add on my HKS Ti exhaust, no cats(AAM test pipes) and a UR light weight pulley.
Old Jun 22, 2010 | 07:48 AM
Blck350z's Avatar
Blck350z
^ Like previously stated change the EMS.... but def. change out the UR pulley!!! your crank shafts stock pulley is also a "harmonic damper" of sorts... and the UR pulley takes all that away which makes it lighter but with the extra trq... I would switch that back immediately!!!
Look at some of the other HR builds .... you might be somewhere around there... as long as you have a nice power curve and a SAFE tune, thats what you should worry about
Old Jun 22, 2010 | 07:51 AM
MDHRZ's Avatar
MDHRZ
I haven't heard of any HR's with the Greddy Emanage. Be careful. I would def reconsider and do it right the first time. Go with Sharif's suggestion.
Old Jun 22, 2010 | 08:01 AM
SV1098's Avatar
SV1098
The Greddy management(which I purchased) was made for the TT kit. It came with the 440cc injectors, harness and the piggy back. It's already pretuned for 6psi.
Old Jun 22, 2010 | 08:05 AM
SV1098's Avatar
SV1098
Here's what it comes with:
Car Make: Nissan
Car Model: 350Z HR
Car Year: 2007-08
Notes: preprogramed Ultimate, full harness, press. sensor, 6x 440cc inj.
for use with GReddy HR Tuner Turbo Kit #11520094
Part #: 350ZEUK
Old Jun 22, 2010 | 08:44 AM
supernadc2's Avatar
supernadc2
Originally Posted by SV1098
Right now I doubt I'll run anymore than 6 1/2lbs of boost. 4-6 months down the line, i'm looking to have the motor built. Once I'm at that stage, I'll look into a standalone.. Haltech or something else
Hehe ... good word to bank off in case cause if your getting a boost controller its harder than you think to control.
Ive been doing pretty good about not going wild but i have had my play time too.
As far as the clutch set up goes yea it would be cheaper to do now but if you cant and later you can take the hit dont worry about it. My factory clutch lasted 22k miles and of those 12k miles was on a regular 7psi daily not bad at all for the factory setup.
Old Jun 22, 2010 | 08:54 AM
MDHRZ's Avatar
MDHRZ
How often do you set it to 10psi? TQ #'s look pretty good.
Old Jun 22, 2010 | 09:54 AM
seymore4's Avatar
seymore4
Professional
Of course Greddy emanage was made for the Greddy TT kit. Doesn't mean that its not complete s___t tho. Ask any tuner who's familiar with FI on VQ's and see how many people have had good luck with it... I wouldn't trust a generic "pre-tuned" one-size-fits-all EMS for the drive to get a proper dyno tune.
But at the end of the day its your motor.
Old Jun 22, 2010 | 10:04 AM
0jiggy0's Avatar
0jiggy0
Looks like a fun build but it seems your ignoring good advice. I would wait till you have some more money and do the clutch and a proper ems.
Also this is your only car and your FI'ing it with no tune and going to DD it? Good luck to you.
Old Jun 22, 2010 | 10:08 AM
supernadc2's Avatar
supernadc2
When im looking for fun i generally tend to set target boost at about 9.5 at the highest because it gains a little higher than 10 under cold temps. I do not drive the car often. And to be honest under vaccum pressure the cars acceleration and performance is great. 99.99% of the time im running 6.5psi. At the moment my target boosts using the HKS EVC are at 6.5 and with the switch of a **** 8.5. I have not had any problems since.
Im trying to find some time to go in for an oil cooler and the new pipes so i can finally put the strut bar back on. Shortly after will come the build which i need to do some research on.
Old Jun 22, 2010 | 10:11 AM
supernadc2's Avatar
supernadc2
Agreed. Hope it all goes well but HR's going boost are on the rise and there actually is a lot of good info out there.
Old Jun 22, 2010 | 10:36 AM
SV1098's Avatar
SV1098
I've built 4 FI cars with no issues. This one, I'm confident will go smooth as well. If the greddy managent doesnt work--it gets removed. This is the absolute least of my worries since we havent even started the build.
Dropping in a clutch and flywheel is 1 days work. Not really a major concern.
I will keep everyone up to date on the build with POSITIVE updates!
Old Jun 23, 2010 | 12:35 AM
illmatic g35's Avatar
illmatic g35
glw build but please change the ems.. emanage blue = noooooooo
Old Jun 23, 2010 | 05:59 AM
SV1098's Avatar
SV1098
Its gun metal but who's checking..lol
Old Jun 23, 2010 | 06:08 AM
  #38
SV1098's Avatar
SV1098
Guys,
I just started breaking down the boxes and going over everything. The one piece I was most concerned about--the IC.
Take a l@@k.
Purchase from Dan @ Speed Concepts.
I've already filed a claim with UPS.
Attached Thumbnails I'm the proud Father of...-dsc00429.jpg   I'm the proud Father of...-dsc00430.jpg
Old Jun 23, 2010 | 06:50 AM
  #39
MDHRZ's Avatar
MDHRZ
Had the same problem with the IC from the same place. Took about 3 weeks to get a new one. Greddy/Trust doesn't package anything well and UPS is horrible.
Old Jun 23, 2010 | 07:40 AM
  #40
SV1098's Avatar
SV1098
I can see that! So freakin pissed!! Why in the world do the ship an IC with other metal parts in the same box?!?
DId UPS come right away to varify the damage? they said they will call today and have someone come out to varify the damage.
