AAM Stage 1 Fuel Return...smells like fuel!
on
I installed a used kit I bought from here and while it works PERFECTLY, my car always smells like fuel. I did some research on it and apparently this was common with the kit that did not have the return line coated but my return line has a silicone ( kinda transparent like ) like sleeve on it except on one small part where I added a bit of line to it. The rest of the setup has no sleeve or coating or anything. Is this normal? I can't see any leaks.
Also, u should buy my machined pulley bc this setup will for sure get u some extra 1-2psi out of your 2.87 pulley.
https://my350z.com/forum/turbos-nitr...s-vortech.html
Some of the early kits (e.g. several years ago) had this issue with sweating lines but that was fixed a while ago...is your kit old/used? Otherwise it could be the seal on your tank which you would know if you only smell it after gassing up. FWIW my stage 1 kit doesn't smell at all, I bought it late-2008.
on
All the time.
I bought it used. How can I tell what kit I have? As for the seal on the gas tank, I epoxied the crap out of the fitting for the return line in the fuel pump housing so I don't think that's the problem.
lol...I already have an idler pulley on for extra belt wrap.
![thumbup](https://my350z.com/forum/images/smilies/biggthumpup.gif)
Evap system is my thought as well.
Mine has been removed and I get a fuel smell....if car is in garage or there is no breeze it is noticable...when moving or in breeze don't notice it.
Tom
Tom
All the time.
lol...I already have an idler pulley on for extra belt wrap.![thumbup](https://my350z.com/forum/images/smilies/biggthumpup.gif)
where do u smell the fuel coming from? Near the regulator or near the fuel pump? I do notice a faint smell of vapor coming from the regulator lines so if it's coming from there u might want to start swapping out the lines with CJM ones or try retightening your aam lines a little more to see if that helps.
on
I'll check that.
did NOT read entire post but two of my buds had this and some of them had the wrong o-ring.
correct size but a fuel vs hydraulic
fuel ate the hydro ring and it leaked right at the firewall right onto the downpipes...
yikes!
check your o-rings and connections for leaks....obviously colder temps will yield the leak easier and faster.
good luck
yikes!
good luck
I think the smell is coming through your firewall not from the back of the car.
if you are driving and smelling while driving a leak in the rear? you would not smell.
i say check under the hood my friend.
no if you smell it a light or something possibly the rear, also if you dont have cats that could also be a culprit.
on
If the Hose-ends are red/blue and the hose is standard s/s then you have a kit from 2-3 years ago.
The kits were revamped at the end of 07. The new kits include black/silver hose ends, the lines are teflon lined and the color of the line is dark silver with a small black weave.
![Frown](https://my350z.com/forum/images/smilies/frown.gif)
yikes!
good luck
yikes!
good luck
on
I tried to see and couldn't find any leaks around there. The fuel pressure will also stay high throughout the night so I'm just going to assume it's because I have the older style kit. Too bad really, but at least I got it pretty cheap.
