Puking coolant....Bottom rad hose still cold???
Old Mar 27, 2012 | 06:14 PM
  #121
SH Luciano's Avatar
SH Luciano
Originally Posted by krivera6950
My mechanic did the install, I can't Smell exhaust fumes but it does seem like hot air getting into the system and causing it to spill out like that, or my other guess is a clog somewhere not letting the coolant pass by, car has new thermostat in and I also poured water threw the radiator but nothing came out
are you na or turbo?
Old Mar 27, 2012 | 06:38 PM
  #122
krivera6950's Avatar
krivera6950
Powerlabs single on the car
Old Mar 27, 2012 | 07:28 PM
  #123
Junkster's Avatar
Junkster
why are you diagnosing?
sounds like an install problem...cometic gaskets have caused problems in a alot of KA-T builds that i have been involved in....my guess would be a headbolt torquing issue...
no way to tell without being there but this is too odd, someone needs to take a dive into this build and take initiative (talk to your mech)
Old Mar 27, 2012 | 08:02 PM
  #124
- bigc -'s Avatar
- bigc -
Here's a link to show what happens to my car when i try using the spill free funnel
http://www.youtube.com/watch?v=93yfeY2aJIQ
this....is not normal. you've got a major issue my friend
Old Mar 27, 2012 | 08:16 PM
  #125
krivera6950
Yea it's def no t normal, I was trying to be positive and hope it was something simple, but in reality hot air is being forced in somewhere and causing the coolant to boil like that and puke out. I doubt it's a clogging issue because the radiator is clean and my heater is working properly. I also had bits of grey RTV sealant come out the funnel a twice. Any thoughts on what this can be?
Old Mar 27, 2012 | 08:53 PM
  #126
Glex25's Avatar
Glex25
Until you don't take it apart it's all speculation
I was trying to be nice about trying the flush trying to give you some hope
but in reality you pretty much knew it would come down to the headgasket
Old Mar 27, 2012 | 09:22 PM
  #127
krivera6950
Thanks I really appreciate it. More then likely Going to look into a build since the motors got to come out to check the headgasket anyways
lapham3
Oct 7, 2022 03:15 PM
EnjukuRacing
Sep 18, 2015 07:57 AM
