Puking coolant....Bottom rad hose still cold???
Old Mar 27, 2012 | 11:55 AM
  #101
krivera6950's Avatar
krivera6950
I have 12 second video but can't upload because is to big, if anyone can shoot me email or phone number i can send the video so you can see exactly what my car does
Old Mar 27, 2012 | 12:06 PM
  #102
Glex25's Avatar
Glex25
Upload it to youtube or Vimeo
Old Mar 27, 2012 | 01:36 PM
  #103
krivera6950
Here's a link to show what happens to my car when i try using the spill free funnel
http://www.youtube.com/watch?v=93yfeY2aJIQ
Old Mar 27, 2012 | 01:59 PM
  #104
ace32x's Avatar
ace32x
ya mines never that bad it just overflows doesnt pop and sput everywhere : /
Old Mar 27, 2012 | 02:16 PM
  #105
Junkster's Avatar
Junkster
Im sorry if i missed something (not reading the whole thread lol).
I recently just had a VERY similar problem on my 510 (KA swapped). Thought it was my Tstat or radiator, even contemplated my the water pump.
Push come to shove it ended up being a faulty radiator cap that was brand new. I put my old L-series cap on and it eliminated all the problems.
My water temp guage sending unit i wired up to the lower rad hose and it was reading cold around 60 f even though the top rad was scortching and cap was puking its guts out.
Thats just my .02 hopefully it helps cause it was kind of a PITA for me haha...specially for something so stupid
Old Mar 27, 2012 | 02:24 PM
  #106
krivera6950
Yea it's weird! When this happens my car starts to overheat but after it stopped spilling and began sucking in coolant the temp would go back to normal. I have no clue what could be causing this. It spills out about a gallon of coolant each time it does this.
Old Mar 27, 2012 | 02:25 PM
  #107
Junkster's Avatar
Junkster
Sorry so i read some of the thread since i felt like a jackazz for posting without doing so lol.
Initial problem is solved so my badz. Thats pretty wild how violent thats bubbling when you try to purge/burp it! Are you still getting brownish residue or buildup?
Old Mar 27, 2012 | 02:55 PM
  #108
krivera6950
Its cool, I dont think it was the rad cap because with the funnel your not using the cap at all and i haven't seen any when burping the system. i have some in my old reservoir. i'll try to post a pick of it. i know i saw some in the hoses in when refilling the radiator.
Old Mar 27, 2012 | 02:57 PM
  #109
SH Luciano's Avatar
SH Luciano
i noticed that funnel looks nearly full. did you pour that much coolant into it? if you did, don't put that much in...just put in enough to fill up the neck of the funnel and add a little bit as the air pockets bleed out.
Old Mar 27, 2012 | 02:59 PM
  #110
SH Luciano's Avatar
SH Luciano
side question, does anybody know how much coolant the reservoir from the APS TT kits holds? i'm researching overflow containers that may fit in that spot but obviously i want more capcity, and my car is not around so i can't measure it.
Old Mar 27, 2012 | 03:02 PM
  #111
krivera6950
This is the sludge that i have in the old reservoir and in the hoses its more of a reddish color
Old Mar 27, 2012 | 03:09 PM
  #112
krivera6950
Picture of sludge!
Attached Thumbnails Puking coolant....Bottom rad hose still cold???-img_0470.jpg
Old Mar 27, 2012 | 03:10 PM
  #113
krivera6950
I filled it up a little less then a 1/3rd of the way full.
Old Mar 27, 2012 | 03:48 PM
  #114
str8dum1's Avatar
str8dum1
damn that sludge looks like crap i took outta a donor motor for my beater that had been sitting for 6 years. essentially the coolant evaporates leaving behind that exact mess.
If I was you i would flush you block. pull your thermostat, put a hose in the radiator and run that til everything comes out clear.
Old Mar 27, 2012 | 03:53 PM
  #115
Glex25's Avatar
Glex25
It's not much I'd say around a quart if that
Krivera that is violent and that sludge is not healthy looking at all
I would try to do a flush and take out T-stat and check in boiling water and see at what temp it opens up if at all.
Worst case scenario I'm leaning towards headgasket even though I know that is not what most around here want to here
Old Mar 27, 2012 | 03:57 PM
  #116
krivera6950
I'm going to do a flush this friday and see if it helps. hoping its just sludge build up that is clogging somewhere
Old Mar 27, 2012 | 05:00 PM
  #117
SH Luciano's Avatar
SH Luciano
sorry if i missed it - is this a stock motor? what mods have you done to your ride?
Old Mar 27, 2012 | 05:12 PM
  #118
krivera6950
Stock motor with cosmetic head gaskets and arp head studs
Old Mar 27, 2012 | 05:51 PM
  #119
Junkster's Avatar
Junkster
did you do the install on this?
smell the coolant as its bubling, you smell exhaust???
this **** is strange like the girl i had over last night lol...
If worse comes to worse i would pull your heads and check things out, possibly do a re-install cause this is definitely not right....im still willing to bet this is some HG issues....i hope im wrong though...
Old Mar 27, 2012 | 06:01 PM
  #120
krivera6950
My mechanic did the install, I can't Smell exhaust fumes but it does seem like hot air getting into the system and causing it to spill out like that, or my other guess is a clog somewhere not letting the coolant pass by, car has new thermostat in and I also poured water threw the radiator but nothing came out
