Puking coolant....Bottom rad hose still cold???
Old Mar 21, 2012 | 06:36 PM
  #81
SH Luciano's Avatar
SH Luciano
damn...and i was hoping this high pressure radiator cap was going to help, but doesn't sound like it did much for you red. i think my next step will be to somehow fit a larger reservoir and see if that does anything.
Old Mar 24, 2012 | 10:57 AM
  #82
krivera6950's Avatar
krivera6950
I managed to put in a bigger resort our then what my powerlab turbo comes with but I'm still having the same issue. After about 15-20 min idling the coolant will sstart boiling in my spill free funnel and start to overflow it. I don't know what could be the cause of my problem
Old Mar 25, 2012 | 09:37 AM
  #83
djamps's Avatar
djamps
Means you have a massive air pocket in your engine.
Old Mar 26, 2012 | 10:18 AM
  #84
krivera6950
Im having the biggest problem trying to get the air out. Also I'm having a reddish brown sludge build up in the hoses and resorvoir, I'm hopping it's not a head gasket and that it's just clogged but I don't know where this sludge is coming from, any ideas? My car starts overheating at idle but not when it's moving
Old Mar 26, 2012 | 10:41 AM
  #85
ace32x's Avatar
ace32x
could just be air that hasnt been bled or its your headgasket
Old Mar 26, 2012 | 11:28 AM
  #86
krivera6950
What's the best way to bleed the system of air, I have the spill free funnel but after about 10-15 min the coolant starts boiling and I have to shut off the car to stop it from from spilling everywhere, do I have to open the bleeder valve
Old Mar 26, 2012 | 01:48 PM
  #87
str8dum1's Avatar
str8dum1
jack the front of you car up when you are using the spill free funnel.
i've never had a purge issue and I've had the motor outta the car at least 6 times. I dont understand why its so difficult for some motors.
Old Mar 26, 2012 | 02:27 PM
  #88
rcdash's Avatar
rcdash
+1. I've introduced air into the system on several occasions but bleeding has always been straightforward. Make sure reservoir (or funnel) never empties completely otherwise you reintroduce air.
Old Mar 26, 2012 | 02:33 PM
  #89
ace32x's Avatar
ace32x
i let mine spilll out, once the thermostat opens it sucks the coolant back in
Old Mar 26, 2012 | 02:42 PM
  #90
krivera6950
I'm gonna try it again this time with car jacked up and see how it goes
Old Mar 26, 2012 | 02:50 PM
  #91
Glex25's Avatar
Glex25
Open the bleeder valve completely while filling it until it spills then close it up and finish it off with the spill free funnel.
Front end jacked up slightly
Old Mar 26, 2012 | 05:22 PM
  #92
krivera6950
So just let it spill out and fill as thermostat opens? I lose quite a bit of coolant when this happens
Old Mar 26, 2012 | 05:29 PM
  #93
ace32x's Avatar
ace32x
yea thats what ive had to do
Old Mar 26, 2012 | 05:34 PM
  #94
Glex25's Avatar
Glex25
I never had coolant spill out of the spill free funnel.
You fill the funnel halfway it gets lower you keep it filling it up.
you never let it get low enough to reintroduce air into the system but you don't have to fill to the top either
Old Mar 26, 2012 | 05:42 PM
  #95
SH Luciano's Avatar
SH Luciano
this.
i bled my car last night and didn't jack it up and was able to get it bled enough to where my temp needle was rock solid at the normal mark after a handful of 2nd and 3rd gear pulls.
just fill the funnel not quite half way and you shouldn't have any spilling out on you.
Old Mar 26, 2012 | 06:16 PM
  #96
ace32x's Avatar
ace32x
i keep mine as low as i can with out getting air back in and it always overflows a little before the thermostat opens : /
Old Mar 26, 2012 | 08:48 PM
  #97
krivera6950
when i did mine i never fill it up no more then a third of the way and it always spills out. I dont mean i slight spill either i mean the coolant is literally boiling out. it almost looks like a wave pool inside the funnel. i could have easily lost 2-3 quarts of coolant when this happens which forces me to turn the car off. I'm going to record what happens to my car with the spill free and see if i can post it.
Old Mar 26, 2012 | 08:56 PM
  #98
- bigc -'s Avatar
- bigc -
that can happen the first time you bleed the system after a drain/refill, but shouldn't keep happening provided you aren't letting air get back into the system when you remove the funnel.
are you letting the engine cool fully with the funnel still in place (make sure the funnel doesn't run dry) before starting the car up again for another round of bleeding?
Old Mar 26, 2012 | 11:57 PM
  #99
350Zdj's Avatar
350Zdj
My friend had the same issue - coolant puked thru the reserve tank after 15mins of idle but never happened while cruising. Turned out it was just the temp sensor that was dirty/loose (according to the mechanic). Now it's running normally.
Old Mar 27, 2012 | 06:29 AM
  #100
krivera6950
Yea i let it cool with the funnel in place, but I usually shut off as soon as it starts spilling out
