Can a dual oil cooler set-up be effectively used??
Old Aug 10, 2010 | 05:54 PM
  #61
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Originally Posted by Cass007
Just a random thought, what about mounting a larger single cooler (GTM) in the rear where the OEM muffler canister sits? Would that get enough airflow from under the car I'm asking because the fron is crowed and that is a big empty space other than the meth pump.
Not big enough, and I wouldn't want to pump oil 10 feet back, and then 10 feet to the front using the OEM mechanical oil pump. There is airflow up front, but you have to get a little creative.
Old Aug 11, 2010 | 05:14 AM
  #62
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
they put the rear diff cooler there because the rear diff is there...and they use pumps You would be talking about one expensive, time consuming, overly complicated system for little to no benefit
it would be alot of expensive work, and a ton of distance in lines as mentioned, to try to cool oil from all that distance at the rear of the car
there is plenty of room in the front of the car, even with the largest of FMIC's mounted, ethough compromises must be made in terms of the body kit, aesthetics, etc. No free lunches
Old Aug 11, 2010 | 09:28 AM
  #63
xzotklr's Avatar
xzotklr
Originally Posted by djtimodj
Guy this is what ive just done for my oil cooler set up. -12an lines mocal Tstat and a 25row mocal cooler.
What about cuting out the entire area and installing plastic or metal air guides inside bumper??
*Note: post modifed..pics removed for brevity
Old Aug 11, 2010 | 09:51 AM
  #64
DaveFunction2ND's Avatar
DaveFunction2ND
Originally Posted by rcdash
Dave my coolant temp usually runs 185-195 and maxes out around 200. My oil temps run 220-240 and keeps on climbing if I don't let off on a hot day. So I don't really see a reason why the OEM oil cooler would be hurting anything...
Where is your coolant temp sensor mounted? Where is the oil temp sensor mounted?
All the oil cooler lines for the radiator come directly off the cylinder heads before they go to the radiator. The fluid at the back of the heads is a significantly different temp then what is in the rad. All the oil cooling is done behind the thermostat.
Old Aug 11, 2010 | 09:54 AM
  #65
DaveFunction2ND
My thought was that as long as the oil gets cool, it wouldn't matter if it is in series or not . Also, I saw a modified mag article where they put a system together using -10 AM lines. Still too restrictive?
Jorge - I was going to run two just to keep a symetrical look, one cooler off to the side bothers me and centering it in front of the IC would make the car look like it has buck teeth IMO.
Dave - Interesting info on the sandwhich plate bypass. Have you done this on any of the Mid-A cars?
Its going to be on Karim's 4.0L build with Vipec and Racepak dash, GTM stage 5 heads, and GTM Stage 3 cams.
Old Oct 4, 2012 | 06:37 AM
  #66
mw9's Avatar
mw9
Any updates?
Old Oct 4, 2012 | 04:33 PM
  #67
Cass007's Avatar
Cass007
Originally Posted by mw9
Any updates?
Function:Tuned is no longer in business. I ran dual Mocal 17 row coolers with a thermostatic sandwich plate and a filter relocation kit. It helped greatly with temps as long as the car was moving in clean air and not in heavy traffic.
Bumping a thread this old ...
lapham3
Oct 7, 2022 03:15 PM
Uriyo_
Sep 8, 2021 08:46 AM
apex locator
Jul 23, 2021 02:27 AM
