Powerlab problem
Old Aug 19, 2010 | 05:25 PM
J_350Z's Avatar
J_350Z
Default Powerlab problem
First I'll start with the a little backstory. I was doing a highway pull when all of a sudden the motor cuts off, dash lights come on and there's smoke coming from under the hood. The first thing to come to mind as I coast to the side of the road is that my motor blew. I get out of the car and pop the hood and notice a gap between the turbine housing and the downpipe(turns out the bolts backed out).
Once the car was back home I did an inspection and noticed a few things
1. 3 of 4 bolts on the turbine back out
2. A plug was melted(see pic)
3. All fluids seem to be at the appropriate levels
4. When I put the key in the ignition and turn to the ON position the radiator fans come on and stay on.
5. The car does turn-over but won't start
So far I've replace the utec and walbro with the stock parts to see if it would change anything.(It didn't) I went to the dealership and picked up a replacement for the plug that melted. When I went to install the plug I noticed the wires were different colors.
The wires from the harness are:
1 green wire and 1 yellow wire with a green stripe
On the new plug the wires are:
1 red with a green stripe and 1 red with a blue stripe
Also I've checked all the fuses( multiple times lol) and looked around for burnt/melted wires.
Any help or ideas?
Old Aug 19, 2010 | 05:55 PM
GreenGoblin's Avatar
GreenGoblin
Think Rich will chime in, but your stock ecu might be toast. I think he threw a cog belt and ate the same wires causing a short in the ECU.
Old Aug 19, 2010 | 08:31 PM
350Z400rwhp's Avatar
350Z400rwhp
There is a set of fuses behind the battery in that area and a large plastic shield needs to be removed (You will need to remove the shield around the wiper blade and the bottom of the windshield too). Your ECU fuse is blown (the reason the fans run all the time). Replace this fuse and your car will start. Go to Autozone and check for codes, P1136 (Manufacturer Control Fuel Air Metering) will be the code you get. You will need to get a new ECU. Hopefully this is not the case but P1136 = Fried ECU
Old Aug 19, 2010 | 08:33 PM
Mr_pharmD's Avatar
Mr_pharmD
ya, i would pick up a stock ecu from ebay and try to see if it works.
Old Aug 19, 2010 | 08:38 PM
350Z400rwhp
Nissan covers the ECU under their emissions warranty for 8 years and 80,000 miles.....
Old Aug 19, 2010 | 08:43 PM
Mr_pharmD's Avatar
Mr_pharmD
I would ditch the stupid allen bolt and replace them with 13mm bolts that are the same length. The kit is great but they went cheap cheap on those and should have made that area with V band or given at least 13 mm bolts.
Old Aug 19, 2010 | 08:45 PM
Mr_pharmD's Avatar
Mr_pharmD
not when they see u temptered with the wires and the motor, lol.
no warranty on performance. period.
Old Aug 19, 2010 | 09:04 PM
350Z400rwhp
True, just need to use your imagination on how to get around that I guess....
Oh and just take the old bad plug and match up the wires so you know which ones go where even though the colors are different on the new plug.
Old Aug 20, 2010 | 06:35 AM
str8dum1's Avatar
str8dum1
yup
+1
you just cant hot swap. needs to be dealer reprogrammed at 150$ or so. Easy to know if ECU is fried. Smoke is a good sign though
Old Aug 20, 2010 | 05:22 PM
J_350Z's Avatar
J_350Z
Thanks everyone, I kinda figured the ecu was shot. Do the 350z and g35 ecu share the same part number?
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
