Need help with my TT install plz
Old Aug 30, 2010 | 01:01 AM
tw8715's Avatar
tw8715
Default Need help with my TT install plz
Alright so i am about to start installing my greddy TT 18g!
My first question is.. do i need a fuel return system???
I am aiming for 400-420 whp.
from reading around it seems like some people have no fuel return system and are getting about the power that i want.
thanks
Old Aug 30, 2010 | 01:17 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
No rfs.
Old Aug 30, 2010 | 04:36 AM
westpak's Avatar
westpak
SFZCC
just the walbro and modify fuel pump assy should get you there
a fuel return is a nicely luxury at those levels but not a necessity, anything beyond that and it is recommended
Old Aug 30, 2010 | 09:27 AM
deanfootlong's Avatar
deanfootlong
well. just like others are saying. I agree. I did a return system just because I know I'll want more later.
Old Aug 30, 2010 | 10:26 AM
tiguy99's Avatar
tiguy99
I'm glad you guys pointed it out bc I'm in the same boat. I would like to have a fuel return setup on my G but wanted to know if it were necessary on stock block 400whp level.
Another question, can having a fuel return system help play a role in increasing your fuel economy? I know everyone hates those two words in this section of the forum but I figured it couldn't hurt to ask!
Old Aug 30, 2010 | 10:35 AM
str8dum1's Avatar
str8dum1
no effect on fuel economy. that is and always has been controlled by your right foot.
Old Aug 30, 2010 | 10:38 AM
djamps's Avatar
djamps
Personally I would never do FI without an RFS. Nothing wrong with an extra safety net, and it simplifies tuning.
Old Aug 30, 2010 | 10:44 AM
jonnylaw's Avatar
jonnylaw
It is my understanding that a rfs will allow for fuel delivery at a lower pressure than just using a rising fuel pressure regulator and is more consistent/reliable at higher rpms?
So using a rfs or not, has no effect on fuel consumption?
Old Aug 30, 2010 | 12:42 PM
str8dum1's Avatar
str8dum1
the fuel pressure is the exact same for a NA car. When you boost, you need to increase your fuel pressure to counteract the effects of the boost.
With stock block FI setups, the fuel pumps have enough flow to counteract, thats why the stock system is ok. When you make more boost, its harder to get steady flow.
If I didnt have a RFS with a 1:1 FPR, my fuel pressure would be 0 at full boost
you are not using less fuel with a RFS, so there is no way it affects economy
Old Aug 30, 2010 | 01:08 PM
jonnylaw's Avatar
jonnylaw
^^makes sense. But do you use more fuel with a RFS or the same as with just a regulator and stock fuel system?
Old Aug 30, 2010 | 04:34 PM
De La Money's Avatar
De La Money
i want to know also. i bet you use more with the fuel return. but thats just my guess
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
