AFR difference between bank 1 and bank 2
Old Oct 17, 2010 | 08:53 AM
OrthoDoc's Avatar
OrthoDoc
Default AFR difference between bank 1 and bank 2
At 5000 RPM in neutral, bank 1 (driver side) and bank 2 show different AFR and it's almost 1.0 difference. I haven't data logged yet, but is it ok?
Old Oct 17, 2010 | 09:11 AM
djamps's Avatar
djamps
Under low load, especially no load, the driver side is always going to be leaner due to the plenum/intake design. As long as you don't see a big difference under load you're fine.
Old Oct 17, 2010 | 09:40 AM
GT-ER's Avatar
GT-ER
I've seen the same as well.
Old Oct 18, 2010 | 12:36 AM
maXmood's Avatar
maXmood
Under Boost!
i've seen about .5 difference.
Old Oct 18, 2010 | 07:29 AM
OrthoDoc's Avatar
OrthoDoc
Thanx for reply. I better data log and see any difference under load.
Old Oct 18, 2010 | 08:28 AM
xzotklr's Avatar
xzotklr
Why not install dual widebands to monitor each bank individually??? Then any significant difference under load would be immediately noticeable??? Just my2c
Old Oct 18, 2010 | 10:17 AM
djamps's Avatar
djamps
He obviously has dual wide bands already or he wouldn't have started this thread.
Old Oct 18, 2010 | 11:38 AM
Sylvan Lake V35's Avatar
Sylvan Lake V35
thats what I was thinking.
Old Oct 18, 2010 | 11:49 AM
deanfootlong's Avatar
deanfootlong
hahahaha. yep.
Old Oct 18, 2010 | 02:18 PM
kartkid's Avatar
kartkid
What I think you have is a lazy O2 sensor on bank 2
that is starting to give up!
Check your data logs and see if the ecm is adjusting the A/F
corrections at nearly the same time. you might find that bank 2 stays longer at one value as bank one is moving around to keep it at 14.7.
Correct me if I am wrong.
Mattg350z
Oct 2, 2015 06:51 AM
350z82
Oct 1, 2015 06:25 PM
