timing chain question
Old Oct 18, 2010 | 04:58 PM
GreenGoblin's Avatar
GreenGoblin
Default timing chain question
I just installed cams, followed the service manual for all the timing marks etc. install went great, I hand turned the motor over with a breaker bar to make sure it turned smooth etc. now my question id there a way to double check the timing now that i have rotated it off TDC? I tried rotating it a few more times to see if the chain would land on the timing marks, with no luck.
Old Oct 18, 2010 | 05:41 PM
ashtrojan2008's Avatar
ashtrojan2008
it will take a lot of turning. but if it is in time, the marks will line up. if i remember correctly gold on crank gear and the lobes on number one will point toward each other, not touching the lifter
are all of the tensioners released? I'm sure its fine.
ross
Old Oct 19, 2010 | 04:44 AM
GreenGoblin
yes when 1 is at TDC the lobes are as you described. I am confident i did it how the serv ice manual described was just looking to double check
Old Oct 19, 2010 | 05:02 AM
Glex25's Avatar
Glex25
ross
^ +1
The sprocket that goes on the crank is much smaller than the sprockets for the cams. As long as you set the timing correctly from the beginning it will line up again just takes alot of turns
Old Oct 19, 2010 | 06:39 AM
Brett@AwesomeZ's Avatar
Brett@AwesomeZ
Vendor - Former Vendor
Count the number of teeth on the chain between the marks, then count the number of teeth you now have between the actual timing marks on the sprockets. They should be the same. You can turn that thing over for a looooong time before the marks on the chain are going to line up again.
Vigman
Nov 17, 2015 04:34 AM
Paul.
Oct 16, 2015 07:34 PM
sccarally
Meet-Ups / Events (Texas)
Sep 27, 2015 01:06 PM
AbyteZero
Sep 22, 2015 09:17 AM
_koubie_
Sep 20, 2015 06:34 PM
