Any input??
Old Oct 25, 2010 | 03:01 PM
Lemans350zTT's Avatar
Lemans350zTT
Default Having some car issues. Need some input
So over the past week or so my car has been running a little rough when not in full boost. Fills almost if its running lean. my A/F is round 11.0. when in full boost there doesnt seem to be an issue still pulls hard all the way to redline. the issue is when taking off at low RPM not in boost. the car fills like it is struggling to get going fills this way in every gear. Idle is fine, as well as everything else.
Any ideas???
Old Oct 25, 2010 | 04:55 PM
rcdash's Avatar
rcdash
What is the AFR when it stumbles? Need to provide more input on your setup...
Old Oct 25, 2010 | 04:56 PM
twitch579's Avatar
twitch579
Weather changing? Maybe run a leakdown/Compression test? Maybe check the spark plugs?
Old Oct 25, 2010 | 06:13 PM
Lemans350zTT
I will diff check that age stumble tomm. Right now I'm on stock powerlabs gt35r running utec 600cc Denso injectors. 7.25lbs boost. Nothing fancy or out the ordinary has been boosted for about 1.5 yrs bout 8-9k miles
Old Oct 25, 2010 | 06:14 PM
Lemans350zTT
Cool cool. Good idea Thx man diff do that tomm.
Old Oct 25, 2010 | 06:51 PM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
11.0 under what conditions: idle, wide open?
Any CEL codes?
Old Oct 26, 2010 | 10:49 AM
Lemans350zTT
Any CEL codes?
11.0 WOT and idle just bounces all over the place AEM A/F gauge, throwing Random misfire right now as well as No cat code
Old Oct 26, 2010 | 04:11 PM
boostedmaxima's Avatar
boostedmaxima
I 2nd checking the spark plugs, check coil packs too.
etkms
Jun 19, 2022 06:30 PM
bcoffee20
Nov 19, 2015 06:39 PM
FromGtoZ
Sep 20, 2015 03:41 PM
torchkc
Sep 11, 2015 08:26 PM
