FINALLY ran a 10 second pass. 10.96@127mph
Old Oct 31, 2010 | 10:03 PM
phunk's Avatar
phunk
CJ Motorsports
good **** bri!
Old Oct 31, 2010 | 11:35 PM
rh_334's Avatar
rh_334
Congrats!
but you should really consider headwork/cams, Z1 recently built a APS TT BB with JWT C2s and +sized valves that made just under 600RWHP without water/meth on an Osiris Tune
Old Nov 1, 2010 | 04:43 AM
Quamen's Avatar
Quamen
Good job! I will have to bring my car down to the track by you sometime in spring when the season starts back up so I can check your car out.
Old Nov 1, 2010 | 05:00 AM
Nealoc187's Avatar
Nealoc187
Originally Posted by rh_334
Congrats!
If he does heads and cams before larger turbos I'll stab him in the face with a soldering iron. His turbos are tapped out, the heads and cams aren't.
Old Nov 1, 2010 | 05:15 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Congrats Brian!
Didnt you use to run Et Streets? How do you like those DR's?
Old Nov 1, 2010 | 05:19 AM
rcdash's Avatar
rcdash
At 14.5 psi? The GT2871s should be reasonably efficient to 20-21 psi? No?
Old Nov 1, 2010 | 05:27 AM
Zivman's Avatar
Zivman
Thinking they are good to around 18 psi. with cams, he probably could get another 75 hp out of them
Old Nov 1, 2010 | 05:37 AM
Nealoc187's Avatar
Nealoc187
negative on all counts. not with the housings they have on them anyways. check out his dyno threads. more boost results in less power. they have no more power left in them, we've tried. if they had 600whp in them we'd have tuned the car to 600whp, no reason not to as the car has all the ancillaries to handle it (that was the original plan) but it cannot get there, not even close.
Old Nov 1, 2010 | 05:49 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Neal is right, anything about 1 bar results more peak torque, but a drop in peak power and a severe drop in top end. Cams would be a band-aid...sure I might get 30-40rwhp more peak power, but I'd give up the perfectly smooth idle and drivability that I love about the car.
If I want more power, I'll be upgrading the turbos.
Old Nov 1, 2010 | 05:51 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Originally Posted by Alberto
Congrats Brian!
DRs are MUCH more stable. As you can see in the vid, the car NEVER gets squirrelly at all. No sway on the top end either. Much more confidence inspiring. Only thing is they are a little more harsh on the drivetrain so I popped a DSS level 2 axle last year with them. Fixed that with DSS pro axles.
Old Nov 1, 2010 | 06:04 AM
Erdem's Avatar
Erdem
I was looking for some HP numbers in your other threads,
but found this instead:
BriGuyMax
Oh *** me!
I I S DRUNk and ir's mostr perplexionmf
__________________
So I'm asking here.. what is it putting down to the wheels?
Old Nov 1, 2010 | 06:08 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Yup, I was pretty hammered that night. Probably shouldn't have been posting. lol
530rwhp and I think 525rwtq on a dynojet
Old Nov 1, 2010 | 06:10 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Definitely, I'd like to check out your's too.
Old Nov 1, 2010 | 06:12 AM
Erdem's Avatar
Erdem
Nice.. sounds like a DD too
Old Nov 1, 2010 | 06:15 AM
jouvert00's Avatar
jouvert00
Nice pass, and decent trap for your psi level.
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
It doesn't usually drive in the rain and never in the snow, but it gets a lot of miles from April to November.
Old Nov 1, 2010 | 06:54 AM
str8dum1's Avatar
str8dum1
thats some great driving! cooler weather FTW!
Old Nov 1, 2010 | 07:09 AM
  #38
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Thanks....I wish it was warmer though...I would have hooked better. I trapped over 128mph back in june when it was over 80 degrees. I just kept bogging out of the hole that day.
Old Nov 1, 2010 | 07:52 AM
  #39
ajcool2's Avatar
ajcool2
time for bigger turbos.
Waiting for your 10 second pass.
Old Nov 1, 2010 | 07:53 AM
  #40
ajcool2's Avatar
ajcool2
Nice job BriguyMax!
