Max Power on my APS TT and build engine
Old Nov 2, 2010 | 11:30 AM
noer's Avatar
noer
Default Max Power on my APS TT and build engine
Hi Guys,
I have the following build:
- VQ35
- APS Twin Turbo
- 2 X Tial Wastegates
- Water Methanol - Devils Own Stage 2
- Arias 9:1 and Pauter Rods
- CJM Stage 1 fuel system
- AAM Max Flow Fuel Pump
- Walbro pump
- 850cc injectors
- 3" APS Exhaust and 3.5" Downpipe
- HALTECH PLATINUM PRO
What is the max power I will get on pump fuel with Meth/water mix.
Regards
Old Nov 2, 2010 | 11:32 AM
str8dum1's Avatar
str8dum1
~500whp, see here
https://my350z.com/forum/forced-indu...96-127mph.html
Old Nov 2, 2010 | 11:50 AM
failsafe306's Avatar
failsafe306
I was running 530whp with the APS kit and built motor, on pump gas. With meth or race gas, we could have gone higher.
Old Nov 2, 2010 | 12:15 PM
John@z1's Avatar
John@z1
Z1 Motorsports
Is this a premium BB kit? Last one I tuned with Osiris made 590rwhp.
Old Nov 2, 2010 | 12:18 PM
Glex25's Avatar
Glex25
Are you running a tuner kit or the extreme kit?
I see you mention Tial wastegate.
I'm pushing 518 on just 13psi and that is on a conservative tune with no meth
Old Nov 2, 2010 | 02:40 PM
Zero260's Avatar
Zero260
I'm making 502whp on 16psi with no meth, and a Utec.
which kit do you have?
Old Nov 2, 2010 | 02:44 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
If it's the 2X Tial wastegates, then it's either the APS Extreme kit which is good for 700whp+ or the APS second gen tuner kit with external gates...good for about 450-500whp.
Old Nov 2, 2010 | 03:43 PM
str8dum1's Avatar
str8dum1
easy to tell by the intercooler thickness..
it wont do 700 on pump/meth though, esp with 1 pump.
Old Nov 2, 2010 | 03:51 PM
deanfootlong's Avatar
deanfootlong
walbro 255......
i'll go with just over 500
Old Nov 2, 2010 | 08:56 PM
Nealoc187's Avatar
Nealoc187
530 to maybe 550ish without cams.
Old Nov 3, 2010 | 05:40 AM
John@z1's Avatar
John@z1
Z1 Motorsports
Premium BB.
Old Nov 3, 2010 | 06:37 AM
captj3's Avatar
captj3
The BB kit will most likely max out around 550 rwhp.
Old Nov 3, 2010 | 08:28 AM
Smasher's Avatar
Smasher
I got 545whp at 17psi on a dynopack. There might be a little more in it with more free flowing exhaust and a couple extra pounds of boost. I get 510whp 16lbs with my berks cats and thats what I run daily. I was thinking on upgrading the Twins to the GT2871's but not sure what I would gain and if it would be worth it.
VQ35
- APS Twin Turbo
- Internal Wastegates
- CP 8.5 and Eagle Rods
- CJM Stage 2 fuel system
- Walbro pump
- 850cc injectors
- HKS High flow Exhaust and 2.5" APS Downpipe
- BC stage 2 cams
Old Nov 3, 2010 | 01:37 PM
rh_334's Avatar
rh_334
did you not see this?
Old Nov 3, 2010 | 04:07 PM
ZEDCAR TT's Avatar
ZEDCAR TT
So far Ive made 533 @ 13psi on a Dynopak. That's a 8.8:1 built bottom end, BC2 cams, Forge actuators (yellow springs)
I'm hoping to come close to 600 with some more boost but the Haltech is already running 60% duty cycle on the boost solenoid so I'm not sure how much more I'll squeeze out of it.
Not going to bother if I have to swap actuator springs or add more wastegate preload as its just too much work when I'm finding it hard to get traction as it is.
Matt
Old Nov 4, 2010 | 07:23 AM
failsafe306
IIRC, Todd from BZM claimed to have made ~600whp on my old APS kit.
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
