Turbonetics Intake pipe install issues, HELP!
Old Nov 13, 2010 | 04:27 PM
Junkyardspecial's Avatar
Junkyardspecial
Default Turbonetics Intake pipe install issues, HELP!
I recently installed the turbonetics kit on my 2003 G35 Sedan, and everything went smoothly except installation of the two intake pipes that run around the engine fan and pulleys. I ended up having to remove the engine fan to fit the pipes in. The pipes never lined up with my brackets and are well in the way of the fan. Is there something I am doing that is way off? Has this happened to anyone before? I ran the car with out the fan for about a mile with no issues at 35mph but It was a test run for exhaust leaks and plan on keeping it parked til the fan gets back in somehow. I plan on taking it to my local shop to ask them for advice if I cannot find a solution.
thanks!
Old Nov 13, 2010 | 06:01 PM
bardabe's Avatar
bardabe
the turbonetics kit was meant to work with the electric fans, if your 2003 Sedan has the mechanical fan that is the problem. you need to switch over to Electric fans, not all 03 sedans had the mechanical fan, but the early model ones had it. i had that issue a couple times with customer cars. is yours a mechanical fan Sedan?
Old Nov 14, 2010 | 05:16 PM
Junkyardspecial
It sure is, How would I go about getting an OEM electric fan, is there a website with it? I couldnt find anything on everything g35.
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
codek
Sep 28, 2015 03:03 AM
samansharif
Sep 25, 2015 12:31 PM
