My BP Single Turbo Kit Review
Old Nov 17, 2010 | 08:22 PM
  #41
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
Dug up my old dyno sheet, and it looks very much like the OP's dyno:
This was with a 6162 T3 .82a/r turbo, so very very close to the T4 .58a/r 6262 the OP has. This was with very conservative timing, just like the OP. Boost pressure was at about 8psi for that pull. So it is safe to say that timing has a lot to do with when the turbo spools, and what the torque curve looks like.
Old Nov 17, 2010 | 08:57 PM
  #42
350XTCz's Avatar
350XTCz
Hmm I guess I might be spooling a bit later too, but I think I have a boost leak that needs to be fixed.
Old Nov 18, 2010 | 03:54 AM
  #43
BCs350z's Avatar
BCs350z
Yea that does look a lot like mine. i agree that it is a little laggy with tq coming in that late. In order for me to be fast i have to be at like 4500 rpms before i punch it, otherwise it kinda feels like a stock Z powerwise until then. Then it rips! I checked for boost leaks and when i looked at the boost log, it doesnt fall off any and hits full boost at 4000 rpms. The wastegate has the 8 lb spring in it but like i said im controlling the WG with an EBC.
Old Nov 18, 2010 | 08:20 PM
  #44
binder's Avatar
binder
I have a 6765 turbo and I see 10psi at 3900 rpms. Something has to be leaking or not working right. especially if you are using an EBC to hold solid boost til 8psi.
Boost won't drop off to show a boost leak because the turbo can provide more pressure than 8psi so it is just forcing it out the leak. It's not a massive leak, but a leak.
I would check from the headers to the turbo hot pipes. That 3 bolt pattern is hard to get nice and tight. if you take those apart i'm sure you will see some exhaust leak on those gaskets.
Old Nov 22, 2010 | 09:34 AM
  #45
scoupe's Avatar
scoupe
i can vouch that DSG has an very low reading DD... my car was actually the one matt tuned to 248 whp from 220 whp. they are indeed great guys to work with and matt knows his stuff. hope you get everything worked out.
Old Nov 22, 2010 | 09:42 AM
  #46
str8dum1's Avatar
str8dum1
no one cares what the dyno read. we are all talking about how laggy his setup is. 800-1000 rpms slower onset of power than any of the other BP kits reviewed here.
Old Nov 22, 2010 | 11:16 AM
  #47
Boosted Performance
Vas had the same issue after his install. The exhaust (header) bolts were not tightened all the way. I think he had a leak on the T4 flange as well.
Old Nov 22, 2010 | 12:35 PM
  #48
Vas_Z33's Avatar
Vas_Z33
yeah that would be my best guess for the OP... either passenger or driver side.. I had a tiny leak... making me not hit fulboost till like 4-5 k lol
Old Nov 22, 2010 | 06:44 PM
  #49
BCs350z's Avatar
BCs350z
should this leak be something i can hear when idling or when driving the car? Because i dont hear an exhaust leak. Or can a leak/leaks be small enough so i cant hear them but enough to have an impact on turbo spool and my laginess?
Old Nov 22, 2010 | 06:57 PM
  #50
Vas_Z33's Avatar
Vas_Z33
the first time this happened to me, i heard it.. the second time I didnt but you could clearly see that the gasket was burnt on one side... and yes a little exhaust leak pre-turbo can make a difference
Old Nov 23, 2010 | 09:31 AM
  #51
binder's Avatar
binder
just because you can't hear it doesn't mean it's not there. Under no boost there isn't much backpressure on the exhaust. When you boost the exhaust starts to build backpressure which will push harder on the leaky gasket therefore causing it to leak.
Old Nov 23, 2010 | 11:51 AM
  #52
BCs350z's Avatar
BCs350z
Im gonna have to check for exhaust leaks. I thought i would be able to hear one if there was one but i guess not. I understand that a leak would cause my laginess but does it effect the torque output also?
Old Nov 23, 2010 | 10:47 PM
  #53
Andrei's Avatar
Andrei
I like this kit. Keeps heat out of the engine bay. So does this kit have potential for 1000whp? Just curious.
Old Nov 24, 2010 | 10:13 AM
  #54
str8dum1's Avatar
str8dum1
no because the biggest turbo that will fit is a 6765. a custom single kit with the turbo mounted by the washer tank could fit a 71+mm turbo though.
Old Nov 24, 2010 | 11:44 AM
  #55
Boosted Performance
This is true as far as Precision turbos go. However a T76 (76mm) does have an S compressor cover that would fit in that location.
Old Nov 24, 2010 | 12:18 PM
  #56
350zion's Avatar
350zion
Professional
This guy has an answer for everything
Old Nov 24, 2010 | 04:34 PM
  #57
str8dum1's Avatar
str8dum1
is that a 1000whp turbo though? the supra guys dont really consider the billet T76 a 1000whp turbo, let alone the cast turbonetics T76
Old Nov 24, 2010 | 07:48 PM
  #58
Andrei's Avatar
Andrei
It's okay. As long as it's near.
Great turbo kit again. Great welds and awesome bends with a clean look. I like it.
Old Nov 24, 2010 | 08:17 PM
  #59
Resmarted's Avatar
Resmarted
I doubt you would hear it, I know someone who had a blitz twin turbo kit who leaked like a **** (1jz). He never knew it until he tore apart the engine. I mean you probably couldn't hear it, all the noise of the engine and the turbo spooling would probably cover it up, unless it is absolutely horrendous, and you weren't holding any boost....
Old Nov 24, 2010 | 08:20 PM
  #60
Resmarted's Avatar
Resmarted
What else would be the point of getting a 71+mm turbo (as you claimed in your other post)? I really don't think the t67's are surging and aren't running out of steam yet, so no real reason to go bigger than for massive hp....
