Cog Belt for Vortech 400% Stronger
Old Jan 3, 2011 | 01:47 PM
OldManZ350's Avatar
OldManZ350
Default Cog Belt for Vortech 400% Stronger
Hay Vortech Guys,
For everyone that Broke a Cog Belt or would just like a Much Much Stronger Replacement.
I've Located a replacement that is 300-400% Stronger.
Depending on Quantity price should be about $36-$50 + shipping
INTERESTED, Add name, year, motor and stock Vortech belt brand & P/N to list
The more people, the cheaper the price may be.
1. OldManZ350.....2003.....non-revup.....Gates 6008mgt20
2. RetcheOne.......2005.....non-revup.....Gates 6008mgt20
3. 350z006..........2006......revup...........Gates 5608mgt20
4.
5.
6.
7.
8.
9.
Old Jan 3, 2011 | 03:01 PM
RetchedOne's Avatar
RetchedOne
I'd try one to be safe...
2005 non-revup
Old Jan 3, 2011 | 03:44 PM
str8dum1's Avatar
str8dum1
if you dont overtension you will never break a cog belt.
Curious, if the new one breaks, what happens then?
Old Jan 3, 2011 | 03:53 PM
Quamen's Avatar
Quamen
Thumbs down
Refund or !?!?
JK
Hope for the Hardcore Vortech guys this helps.
Old Jan 3, 2011 | 04:39 PM
Mr_pharmD's Avatar
Mr_pharmD
ya I never had a cog belt break on me and I dont really see why it would unless u over tighten it. It doesnt really have that much stress compared to the serp belt but for safety I would have paid the extra buck (cheaper than replacing the cam sensor and ecu if the cog belt breaks).
Old Jan 3, 2011 | 06:17 PM
str8dum1's Avatar
str8dum1
ya mine only broke bc it was overtensioned.
Old Jan 3, 2011 | 07:42 PM
MDK's Avatar
MDK
How the hell do you break a cog belt?
Old Jan 3, 2011 | 08:16 PM
350z006's Avatar
350z006
3. 350z006..........2006......revup...........Gates 560-8MGT-20
4.
5.
6.
7.
8.
9.
Old Jan 3, 2011 | 08:18 PM
RetchedOne's Avatar
RetchedOne
How tight is too tight.. cause my tensioner is all the way down, and I can still move the belt side to side on the pulleys...
Old Jan 3, 2011 | 08:40 PM
OldManZ350's Avatar
OldManZ350
1/2-3/4" play DEAD COLD. Check after HOT, Belt will tighten up a bunch after getting up to full temp, Belt should still have a very small amount of play, not tight.
Old Jan 4, 2011 | 09:30 AM
jpc350's Avatar
jpc350
not to be ****, how do you know it's stronger than the gates??? Who makes em?
Old Jan 4, 2011 | 10:49 AM
OldManZ350's Avatar
OldManZ350
Mr. ****,
I was told by Gates, "There is Nothing Tougher"....
The 400% came from a Global Power Transmission & Belt Suppler. I spoke with a very experienced guy in their Technical Dept.
If it were 50% Stronger I'd buy one. I ordered mine yesterday. (Huge difference) 50% is the same difference as 600HP is to 400HP, Is that's Huge?
I'm researching to get actual Data.
I've spent many many Hours Researching all different types of Belts available for different applications, for a project I may do in the future.
As their is little Interest in This Belt, I may just give everyone the P/N's and Source, then they can just buy it from them.
The Info is out there, you just have to work at it a little....
TimRod
Old Feb 28, 2011 | 06:39 PM
ohhdangz's Avatar
ohhdangz
Not trying to be argumentative but since when does heat make a polymer contract?
Also, the gates belt should never break unless grossly neglected. It occasionally needs tightening and worst case scenario will lose some teeth. It should be inspected regularly. Its also a good idea to have a spare in the glovebox with the wrenches needed to change it out. Especially if you are not accustomed to regularly checking it.
im in the market for some more belts because i just noticed my last one had a tooth or two missing. Sadly many of the sites to purchase them are blocked here in "Undisclosed location" that im currently deployed to.
the best price i have been able to find is $22ish. I did see one for $18 but cant get to that site. Anyone know any places online that sell for around $15? I found a place a while ago that sold it for around $12-15 i think. it said it was for a washer or dryer, lol. Any help would be greatly appreciated.
Thanks,
Mitch
Old Mar 1, 2011 | 06:16 PM
OldManZ350's Avatar
OldManZ350
Thanks,
Mitch
Hi Mitch,
Fact: When the car is up to Temp, Cog Belt is Tighter. Do a Test you will see.
Fact: Some people on here have broken belts, of corse from improper adjustment, (Too Tight Cold) so they do Break.
Given enough Load, everything has it Breaking Point.
I was doing research for a stronger belt because I'm Building a Custom YSI System for 30-35 PSI.
I thought I'd let people know what I found, but Little or no interest.
Thanks,
TimRod
Old Mar 1, 2011 | 07:50 PM
350z006's Avatar
350z006
Keep us up to date on the YSI system...I'm curious to see how much mods are required to fit that blower in the Z...
Hi Mitch,
Fact: Some people on her a broken belts, of corse from improper adjustment, (Too Tight Cold) so they do Break.
Thanks,
TimRod
Old Mar 2, 2011 | 06:13 AM
mafoor's Avatar
mafoor
^^+1
I was thinking about trying to make a YSI fit but it would be pointless with a 6-rib setup.
Old Mar 2, 2011 | 07:25 AM
Quamen's Avatar
Quamen
A YSI shouldn't require a ridiculous amount of work to fit. I compared an S trim to our YSI and it wasn't to much larger.
Old Mar 2, 2011 | 10:26 AM
str8dum1's Avatar
str8dum1
^hah, I've been saying that for 3 years. At worst you'd have to trim the radiator support and move AC lines. good to see someone step up! :thumbup"
Old Mar 2, 2011 | 01:57 PM
OldManZ350's Avatar
OldManZ350
Originally Posted by mafoor
^^+1
Mine will have a 10 Rib Setup, with a Stronger and Wider Cog Belt.
Old Mar 2, 2011 | 02:50 PM
mafoor's Avatar
mafoor
damn i cant wait to see that!
